Caliper piston tolerance
Home › Forums › General Questions › Caliper piston tolerance
Viewing 15 posts - 1 through 15 (of 15 total)
  • #140260
    Mark P.
      @markp
      Hi all. I have been making a set of 4 stainless pistons for my motorbike,on completion I find that they are all .03mm undersize they should be 30.18mm I've ended up with 30.15mm. The question is will they be OK to use or shall I remake them? I think that they should be OK as the seals should take up the.03.
      Regards Mark P.
      #23064
      Mark P.
        @markp
        #140266
        David Jupp
          @davidjupp51506
          Since your life, and perhaps the lives of others could depend on the brakes, it might be better to make sure your new pistons are within the original dimensional specifications just to be sure (if you can find out what the spec was).
          I'd be surprised if anyone here will tell you it's OK – especially with no detail of the seal arrangement, fluid pressures etc.
          #140270
          Ian P
            @ianp
            Whether 0.03mm difference matters can only be determined with reference to all the original data and its unlikely that you will be able to get that.
            First question though is, where did you get the 30.18 dimension from, was it by measuring the old piston? If it was then it seems an odd number. If you use the same instrument to measure the originals and the ones you have made then it does not matter that it is not calibrated to a traceable standard as you are just using it as a comparator really.
            If it were my vehicle I would accept that size difference and ride or drive it without the slightest concern (The diameter difference is less than a 0.1% change) Probably the most important single factor is the actual surface finish which needs to be perfect.
            Ian P
            #140280
            Mark P.
              @markp
              Hi Ian I got the dimension 30.18mm by measuring the origional piston, I suspect that the true size should be 30.00mm. I have a very very fine surface finish done with 24000 grade paper. I think I will go with them.
              Mark P.
              #140284
                Nothing odd about 30.18mm though I suspect it should be 30.16mm which is 1 3/16" What make is the bike, would it have been imperial?
                What does your insurance company say about having home made parts?
                J
                Edited By JasonB on 10/01/2014 20:47:56
                #140287
                blowlamp
                  @blowlamp
                  If the pistons are a decent fit in the bore and are nicely gripped by the seals, then I can't see there being a problem. As the pressure increases the tighter the seal will hold against both piston and bore, due to the deformation of the seal.
                  Martin.
                  #140291
                  Ian P
                    @ianp
                    Jason
                    I only have casual knowledge of motorbikes but 'fitted with disk brakes made to imperial dimensions' does not seem likely.
                    Good question about the insurance aspect but it must be possible to insure vehicles that the manufacturers parts are no longer available. I would rather trust parts I made myself than those from some backstreet operation.
                    Ian P
                    #140298
                    Clive Hartland
                      @clivehartland94829
                      The seals will have a chamfer on the contact side and as the pressure of the brake is removed the chamfer draws the piston back a small amount to stop the piston and pad from binding on the disc. I doubt the 0.03mm will make the slightest difference to this action at all. If anything it may increase this drawback which may give you some extra movement when the brake is applied.
                      #140303
                      RJW
                        @rjw
                        Almost there Clive, piston seals are generally of a square cross section, and it's the base of the seating groove in the caliper that's angled, this angle tilts the seal in the groove so that the inner edge (facing the inside of the caliper and bearing on the piston) is of a slightly smaller diameter!
                        It's the tilt on the seal that creates both the seal and 'grip' on the piston and also helps 'return' the piston when the brakes are released so that the pads don't bind, yet keeping the piston in close contact to the pad and preventing it from being sucked back into the caliper by the hydraulic action of the master cylinder piston returning!
                        Such a miniscule difference in piston size in my view ain't going to cause any grief as long as there's no excessive wear in the caliper bore where it operates, the piston doesn't seal the bore, the seal does, but the clearance shouldn't be enough to cause the seal to be deformed by a sloppy piston fit and leak!
                        In all my years as a motor engineer, I've never seen any caliper wear to such a degree, but corrosion on cast iron or alloy calipers and pistons are generally their downfall not wear!
                        As for 'home made', why not? as long as it's well machined and polished and of decent material who is to say it's not an aftermarket product, there are loads of companies making these products as conversions for the classic car market!
                        Anonymous
                          What bike? you'll find that the OE workshop manual and even a Haynes one has the brake piston tolerance sizes for most models. I've made stainless pistons for several of my past bikes using the manual specs. As an example a close one to the OP ones are 30.23 to 30.28mm on 4 pot Suzuki front calipers which is found in both Haynes and the OE manual..
                          Edited By Mick Berrisford on 10/01/2014 23:38:46
                          #140315
                          stevetee
                            @stevetee
                            0.03mm sounds a bit like 0.0011" thats one and a tenth thouths in English. Just how accurate do you think they need to be?
                            All machined parts have a tolerance …. a thou undersize is nothing, now if they were a bit oversize I would be more worried as they would be likely to sieze in the casting as the pistons heat up in use. As long as they are smooth then I for one would say they would be fine at the size they are. If I was a production engineer and you wanted me to put a tolerance on them then I would say they should be the nominal size +000" – 0.002" or 0.05mm in metrickery.
                            #140327
                            Involute Curve
                              @involutecurve
                              I make my own callipers, and pistons all the time, you will be fine with this tolerance, I made a jig years ago for testing how much you could get away with in this respect, I also used this same jig to gauge the pull back effect of differing tapers on the seal seat outer face and its amazing how big a gap they will seal.
                              Shaun
                              #140328
                              Brian Wood
                                @brianwood45127
                                Mark,
                                It may add confidence to this discussion with some measurements from salvaged brake pistons from our old Landrover.
                                These were for drum brakes, but the principle concerning lip seals still applies. The larger are 31.66-31.68 mm diameter, the smaller are 25.32-25.33 mm in diameter. There were 4 of each size. They are hardened with a chromed finish.
                                The brake cylinders in which they operated were all aluminium alloy, it was those that corroded from the conbined effects of road salt and agricutural manure spray that found it's way into the drums. a devastating mixture. It would eat holes in a chassis in a few seasons!
                                I hope that helps with the tolerance concerns.
                                #140345
                                Mark P.
                                  @markp
                                  Well who's a numpty then? Thanks Mick I looked in the manual after you had reminded me, never thought to look in there! Anyway the ones I have made are in tolerance (30.12mm – 30.2mm) Thanks for the replies panic over.
                                  Regards Mark P.
