I had this problem repeatedly a few years ago with my Boxford when it was situated in a cold unheated workshop. Worked normal for a few minutes then a gradual slowing of the spindle to zero speed and a squeal from the v belt and the motor dropping below the centrifugal switch speed, kicking in the start winding and then cutting it out again a second or so later. The pulley was effectively locked solid to the spindle.
It was eventually traced to a lack of end clearance / lubrication on the multistep pulley (item 250) that fits over the spindle. Remove the two grub screws in the bottom of the v groove, lubricate with lathe oil, replace the grub screws and run under no load for 10 mins or so, with both the sliding gear and back gear disengaged such that you are only driving the v pulley and nothing else (the spindle may drag slightly)
If no improvement and the pulley stops again then back off the nut 119 by a smidgen. A blow or two from a nylon or hide faced mallet on the non chuck end of the headstock might be useful.
The method of setting the bearing preload is detailed in the Boxford spare parts leaflet which should be floating around online, my experience says it is very temperature / bearing grease dependent, and the setting is in my view maybe on the high side. What preload works now could easily be useless come mid-summer.
http://www.boxford-software.com/spares/3656HeadMk1.html
