Kerry Super 8 Speed Drill
Home › Forums › Manual machine tools › Kerry Super 8 Speed Drill
  • #822367
    GrahamS
      @grahams
      My venerable Kerry Super 8 drill’s drive belt is looking very tatty and I am thinking about replacing it.
      Does anyone have a link to a replacement belt or enough details to order one with confidence ?
      From surfing about it seems to be a type A42 V belt, but I cant find more details with dimensions.
      #822372
      howardb
        @howardb
        #822381
        Martin of Wick
          @martinofwick
          Those are the  dimensions 42in and A section – more  economically from the link below…..
          A42 (13×1067 Li) V Belt
          From bearing shop UK  (sorry never seem to get the link to display properly).
          #822385
          bernard towers
            @bernardtowers37738
            Nows the time to take the top cover off and paint the details on the inside!. If only I remembered to do that.
            #822387
            howardb
              @howardb
              Fom the Lathes Ltd link to product.
              “Kerry “Super 8” & “Drillmaster” drive belt. UK or EU-made high-quality, machine-tool grade belt with an invisible joint that, unlike the cheap imports, does not bump as it goes around the pulleys and so ensures the smoothest possible drive.”
              I’ve been caught before with buying cheap belts from bearing suppliers, sometimes it doesn’t matter – for your mower for example – But they do tend to have a lump where the joint is, not something I would want on a pillar drill.
              “You pays your money and you takes your pick” as they say.
              #822400
              Chris Crew
                @chriscrew66644
                I must say that I have never had any problem with cheap belts that I have bought from a well-known auction site. The belt on my Taiwanese drill-press, that several people told me at the time I was a fool for buying, only lasted forty-years!
                #822421
                larry phelan 1
                  @larryphelan1
                  Chris I think you should bring that belt back and demand a new one !
                  41 YEARS ?? Not good enough.
                  Sudden thought !  I bought my similar drill in 1983, maybe I should check my belts too ?
                  #822513
                  GrahamS
                    @grahams
                    Thanks for these posts.
                    Using the above info I have gone with this from Amazon including next day magic.
                    http://www.amazon.co.uk/dp/B0BMTGW2D7?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
                    Like for like swap, no visible joint or lumps etc fitted and runs perfectly.
                    Used for a couple of hours with no issue.
                    Over the years I have bought many items from lathes.co.uk so have no guilt paying half the price from somewhere else.
                    Thanks again.
