very low temp solder
Home Forums Beginners questions very low temp solder
  • #186424
    nigel jones 5
      @nigeljones5
      I need a low temp solder to seal a part on a tender. Its soldered together with leaded plumbing solder so I guess it melts 180-250 degrees. Is there anything which will work for brass below this temperature?
      #7567
      nigel jones 5
        @nigeljones5
        #186426
          Useful info from Multicore, here.
          John Baguley
            @johnbaguley78655
            Hi Fizzy,
            Have a look at the Carrs range of solders as used for building etched brass kits. Some of those are low melting point and I've used them in the past for various jobs including soldering tanks and tenders. I got my stock from C&L Finescale.
            FMES
              @fmes
              I've used ordinary electrical flux cored solder to good effect on brass tanks and tenders.
              #186436
              Bruce Edney
                @bruceedney59949
                JB Weld? – Web site says good to 550 deg F (about 280 degC)
                #186438
                Muzzer
                  @muzzer
                  VERY low? Try Woods metal / bend alloy etc (70C)!! How low can you go?
                  #186444
                    There are special solders that people who make white metal kits use. Chronos and Tiranti both sell a good selection.
                    Les Jones 1
                      @lesjones1
                      Hi Muzzer,
                      How about mercury. Minus 38.83 Deg. C
                      Les.
                      #186492
                      OuBallie
                        @ouballie
                        Posted by Les Jones 1 on 15/04/2015 09:01:27:
                        Hi Muzzer,
                        Les.
                        Smart arse!
                        Geoff – Nice one Les thumbs up
