For aluminium, a much greater top rake than that used for steel is often recommended – at least 15 deg, and up to as much as 35 deg. If your tools were pre-ground for steel, .the angle will be much less.
That said, I don't use anything special for Al, and my results are OK (though my standards are not terribly high!).
Are you using a fine power feed, or winding the saddle along by hand? If the latter, try cranking very slowly indeed.
One problem with Al is that it is gummy, and a blob of it can build up on the tool tip, altering the geometry and impeding chip clearance. Using WD40 or paraffin helps to prevent the build-up.
Andy.
