Lathe really crap finish – Myford ML4
Home › Forums › Beginners questions › Lathe really crap finish – Myford ML4
Viewing 15 posts - 1 through 15 (of 15 total)
  • #99777
    Dean Godfrey-Cooke
      @deangodfrey-cooke74440
      Hi All
      I finally got around to playing with my lathe at the weekend. I was just getting some practice with the new HSS tools I have, cutting a few grooves in some aluminium I had knocking around.
      It was chucked in and held by a rotating centre but whenever I tried a finishing pass the surface was just shocking, uneven ridges all teh way along. I tightened up the jibs to see if it was a little loose but no luck
      Where do I look next? The tools were new and sharp.
      Cheers
      Dean
      #6367
      Dean Godfrey-Cooke
        #99779
        Martin W
          @martinw
          Dean
          Do you know what grade the aluminium is? If not dump it and buy or get some that you know is good for turning. Something like HE30 normally turns nicely especially if you use WD40 or white spirit as a cutting lubricant, this can be applied using a small brush.
          If this doesn't do the trick then check your tools to make sure they are really sharp. Try reducing the cut depth and feed rate to see if this helps. It's worth noting that tools with very sharp points/noses, non radiused cutting ends, can leave a trace on the surface like a fine screw thread.
          Cheers
          Martin
          #99785
            Make sure the cutting edge is exactly on centre height and also use some form of cutting fluid WD40 or Parrafin work well on ali
            #99788
            jim both
              @jimboth37830
              It could be the Ally. We had a job at work with some free issue (customer supplied) Ally, job looked a doodle. Turned out to be the worst maching metal i'd come accross in 30 years. it cut like LEAD!!!
              i made sure non of the bar ends fell into my bag on that job!!!!
              #99792
              Boiler Bri
                @boilerbri
                If you pm me i will send you a sample of HE30.
                Bri
                #99804
                Phil H 1
                  @philh1
                  Dean,
                  You might laugh at this and I hate to admit it but I was very puzzled one day at the poor finish until I realised the spindle was rotating backwards!!!!
                  Otherwise, the usual checks like centre height, spindle speed, rigidity of the tool and workpiece etc.
                  Phil H
                  #99805
                  Andyf
                    @andyf
                    For aluminium, a much greater top rake than that used for steel is often recommended – at least 15 deg, and up to as much as 35 deg. If your tools were pre-ground for steel, .the angle will be much less.
                    That said, I don't use anything special for Al, and my results are OK (though my standards are not terribly high!).
                    Are you using a fine power feed, or winding the saddle along by hand? If the latter, try cranking very slowly indeed.
                    One problem with Al is that it is gummy, and a blob of it can build up on the tool tip, altering the geometry and impeding chip clearance. Using WD40 or paraffin helps to prevent the build-up.
                    Andy.
                    #99810
                    KWIL
                      @kwil
                      It is not that Ali is "gummy" it just happens to have a relatively low melting point and "welds" itself to the tool if the tool is not correct or in some circumstances not lubricated.
                      #99814
                      Wolfie
                        @wolfie
                        I had this problem and in my case my lathe tool was too sharp!
                        #99819
                        ianj
                          @ians
                          Posted by Phil H 1 on 01/10/2012 13:07:16:
                          Dean,
                          Phil H
                          I can remember once at work one chap drilling some mildsteel angle iron cursing the crap drill bits until it was pointed out he had the drill on reverse !!
                          Ian
                          #100506
                          Dean Godfrey-Cooke
                            Thanks for all the responses guys.
                            When I get some time I'll try some other Alu and the suggestions above. I wasn't using any lube so it could be that simple, though the spindle was going the right way 😀
                            Wolfie, too sharp?
                            I bought the tools from RDG on their recommendations for Alu, I also have some Warco Indexable tipped tools but haven't tried them yet.
                            Cheers
                            Dean
                            #100513
                            Terryd
                              @terryd72465
                              Sorry – error
                              Edited By Terryd on 11/10/2012 15:39:17
                              #100515
                              KWIL
                                @kwil
                                CCGT-AK tips for aluminium are extremely sharp with a high top rake.
                                #100516
                                Martin W
                                  @martinw
                                  Dean
                                  I think Wolfie is referring to the point I made in my initial post on this thread that if a tool has a pointed cutting end rather than a radiused cutting end then it can leave fine grooves in the turned piece. Often to get a really smooth surface it is necessary to grind a small radius on the end of the tool. The cutting edge still needs to be sharp with a rake ground on the top surface. There are many books and tables that give these relief angles for different materials etc.
                                  Indexable tools will have as part of their reference code a number/letter which which defines the tip radius, so by picking a larger radius tip you can effectively make a smoother cut at the same tool traverse speed.
                                  Hope this helps
                                  Martin
                                  Edited By Martin W on 11/10/2012 16:30:17
