X2 Mini Mill – Motor Armature
Home › Forums › Help and Assistance! (Offered or Wanted) › X2 Mini Mill – Motor Armature
  • #362826
    Keith Wood 1
      @keithwood1
      After many years of good service, the DC motor on my X2 mini mill started its periodic popping and arcing.
      Upon stripping the motor I found the commutator grooved so I skimmed it in the lathe, after finishing the clean up I noticed that there was no meat left for another future skim.
      I purchased a brand new armature and installed it in the old casing, installing a new set of carbon brushes.
      After re-installation and power on I noticed that the motor ran up to speed well but was not stable speed wise, also there is no torque on start up and minimal torque during running.
      I re-installed the old cleaned up armature in order to troubleshoot and there is plenty of torque and the speed is stable.
      I checked the new armature with a multimeter, the 180 degree check between segments shows good. The adjacent segment check shows good and the individual segment to laminates shows good.
      Anybody any ideas.
      I have since purchased a new motor and will keep the old motor with skimmed armature as a spare.
      Thanks
      Keith Wood
      Montreal
      #33239
      Keith Wood 1
        @keithwood1
        Motor re-build problems
        #362831
        John Haine
          @johnhaine32865
          Presumably your mains is 110 V? Maybe they've sent you a 220 V component?
          #362833
          Keith Wood 1
            @keithwood1
            Yes, mains supply is 110v.
            The armature was supplied by a supplier in the US and I believe all the motors use around 90vDC supplied from the controller.
            Maybe you are correct.
            Regards.
            Keith
            #362838
              My UK X2 has a motor plate that reads DC 230V.
              Keith Wood 1
                @keithwood1
                I think you have clarified the situation.
                Maybe the armature manufacturer sent the incorrect ones to my supplier.
                I will relay this information to them.
                Best regards.
                Keith Wood
                #362849
                John Rudd
                  @johnrudd16576
                  Posted by Keith Wood 1 on 18/07/2018 14:51:59:
                  Anybody any ideas.
                  Thanks
                  Keith Wood
                  Have you compared the dc resistance between the two armatures?
                  #362854
                  Dave Shield 1
                    @daveshield1
                    Had problems like that on a washing machine.
                    The brushes were floating off the armature when the motor was ramping up.
                    Dave Shield
