Worn saddle fix. Is this a bad idea?
Home › Forums › Beginners questions › Worn saddle fix. Is this a bad idea?
  • #10720
    JDS
      @jds
      #530942
      JDS
        @jds
        The saddle on my 1971 S7 does not cut square when the gib's are adjusted up.
        From reading up on here this is not uncommon and there is a fix by converting it to a wide guide. This involved machining back or off the shorter inner saddle guide so the saddle runs on the 2 outer most shears.
        I have fixed this problem on my lathe without any machining work and it seams to work great so I am worried that I have missed something or I am going to damage the lathe.
        All I did was loosen the gib screws off and insert two 0.4mm feeler gauge blades one on either side of the saddle in between the saddle and the and the rear most vertical sheer. Re tighten the gib screws and hey presto jobs a good un or so it would seam.
        The only issue is that the feeler gauges can slip out but that is easily fixed.
        My question is. Is this a bad idea? Can this increase ware on the shear more than the saddle running directly would. What have I missed.
        This seams like such a simple solution and it seams to have worked, but any advice and guidance is much appreciated
        Edited By JDS on 01/03/2021 11:47:32
        #530950
        ega
          @ega
          Essentially, you have done what I did successfully some decades ago.
          NB that you may need to re-adjust the apron to the saddle so that the half nuts are gripping the leadscrew correctly.
          Edited By ega on 01/03/2021 12:06:06
          #530963
          larry phelan 1
            @larryphelan1
            Not much new under the Sun, is there ?
            #530964
            ega
              @ega
              Posted by larry phelan 1 on 01/03/2021 13:26:46:
              Agreed.
              But was J A Radford the first to propose this kind of solution for the weakness of the Myford design?
              #530965
              JDS
                @jds
                Hi thanks for the reply
                That's good know it has worked for you and a good tip on the Half nuts yes cheers.
                I have read the Radford solution but I don't have access to a mill.
                Happy days that another job to tick off.
                Thanks laugh
                #530969
                ega
                  @ega
                  PS See also Richard Gandertons' article in Home page reprints.
                  #531012
                  Martin Dowing
                    @martindowing58466
                    I am aware that many people done what you describe, usually with success.
                    But why not to scrap back to shape original guide or/and a lathe shear as necessary?
                    #531037
                    JDS
                      @jds
                      I did think about trying to but I am not sure I am skilled enough not to screw it up.
                      hopefully I will be able to afford a bed and saddle regrind at some point but probably not for a few years yet. So if I can avoid removing material now that is the safest betyes
                      #531075
                        Can't be a bad idea as Myford changed to using the system on later S7s.
                        duncan webster 1
                          @duncanwebster1
                          This might be a stupid idea, but you can buy Glacier DU bearing as strip, could this be glued to the rear shear?
                          #531086
                          peak4
                            @peak4
                            Posted by duncan webster on 01/03/2021 22:01:23:
                            Never used that, but I did use some Tribo Tape B160 when I refurbished my surface grinder.
                            I bought enough to do the same job on my Myford S7. It should be just thick enough to give clearance, without causing problems by moving the saddle too far to the rear.
                            https://www.igus.co.uk/tribo-tape/tribo-tape
                            Bill
                            Edited By peak4 on 01/03/2021 23:53:59
                            #531100
                            Alan Charleston
                              @alancharleston78882
                              Hi Bill,
                              Is the Tribo Tape B160 the same as Turcite which I believe is teflon loaded with bronze powder?
                              Alan
                              #531101
                              Hopper
                                @hopper
                                Posted by JDS on 01/03/2021 19:19:17:
                                Use the Barker Method of wide guide conversion described in detail in MEW 287 and you won't have to remove metal and will not need a milling machine, unlike the Radford and Ganderton methods.
                                It consists of doing more or less what you have started: add a strip of gauge plate along that back edge so it bears on the very rear shear instead of the worn front shear. The article describes using 1/16" or 3/32" gauge plate, but others on here have used a thinner strip of feeler gauge material and loctited it in place.
                                The Turcite tape sound good too.
                                I would not use the soft Glacier bearing material for fear swarf would embed in it and make a nice grinding surface.
                                #531102
                                Neil Lickfold
                                  @neillickfold44316
                                  I added constant oiling to my S7. I just change the viscosity of the oil until it works. Currently using ATF oil with a bit of lucas oil stabilizer. Works really well. With hindsight I should hav eused 6mm fitting instead of 4mm  fittings. The 4mm is a bit restrictive with the oil. If i need a higher viscosity, it will need the bigger id tubing.
                                  Edited By Neil Lickfold on 02/03/2021 07:44:09
                                  #531136
                                  Hopper
                                    @hopper
                                    Posted by Neil Lickfold on 02/03/2021 07:42:42:
                                    Is that using a pressure feed? What do you use to make the pressure? Is there are commercial system that can be fitted?
                                    #531211
                                    peak4
                                      @peak4
                                      Posted by Alan Charleston on 02/03/2021 07:20:29:
                                      Hi Bill,
                                      Alan
                                      As far as I'm aware, it's just a very hard, but slightly flexible plastic of uniform thickness.
                                      You can get plain or self adhesive, when I measured my own Myford S7, I reckoned I needed the self adhesive for the extra thickness; it should give me enough thou clearance without machining the saddle casting.
                                      From what I can gather, it's significantly cheaper than stuff such as Turcite.
                                      It's probably even cheaper than a couple of bits of 12" Starrett feeler gauge strip
                                      Bill
