Yep, that’s about what I drew. After thinking about the problem I realised it might be of interest to the Freecad team, so I found the FC forum to post about it. I didn’t feel like signing up to another forum I may never visit again, so I didn’t bother. What I did discover is my version, 1.1, wasn’t the latest version, there was 1.1.4, so I downloaded it. This time I saved my drawing at each design step, especially when I came to section it! There problem was still there. I opened the file in ver 0.19 added the fillets to the bolt bosses on the flange. The fillets tried to follow a straight line around the boss instead of curving. I went back to ver 1.1 and modified the sketch so there was plenty of room for a 1mm fillet to exist by raising the plane the bosses sketch lives on by an extra half a mm to 1.5mm above the flange. Before padding the bosses I filleted the outer edge of the flange by 1mm. The bosses were then padded down by 6.5mm to the bottom of the flange. The bosses would then take a 1mm fillet. I saved the file and drew the square to section the cylinder. It sectioned perfectly. I will play with ver 1.1.4 until 23.6 is released.
This is the sort of thing I design using Designspark mechanical. A 7 cylinder radial engine. Total fantasy design, not much realism in its functionality. I have 3D printed most of it with only the carb and manifold left, plus anything damaged or missing. I can’t make them in metal, so plastic will have to do!
I make the valve springs from copper wire wound round a former designed in FC 0.19 and printed on my Ender3. A clipped nail glued in a hole down the middle gives it strength. The springs will be 6mm dia.
Lee
