Painting stainless steel
Home › Forums › General Questions › Painting stainless steel
  • #868737
    Colin Teasdale
      @colinteasdale
      I have acquired a part built model which has a stainless steel smoke box, which I would prefer painted.
      Is there an etch primer that is suitable for stainless, or is it a case of ‘rough up the surface’, to provide a key, and hope?!
      #868763
      bernard towers
        @bernardtowers37738
        according to the blurb Jenolite etch primer is good for stainless.
        #868789
        Baz
          @baz89810
          Don’t bother with Phoenix Precision Paints etch primers as their site says it’s ineffective on stainless steel, also all their etch primers are out of stock, and have been for at least six weeks, two ignored emails asking when they were likely to restock totally ignored and a phone call asking got the reply sometime soon. Make sure that whatever etch primer you use can handle the heat of the smokebox, I know that Upol Acid#8, available in car accessories shops will take the heat as I have used it on ally smokeboxes with a high temperature black gloss over it but don’t know if it will stick to stainless. I believe Hammerite do a speciality metals etch primer but again don’t know what temperature it will take.
          #868850
          Colin Teasdale
            @colinteasdale
            Thanks for the information, chaps.
            Baz, it was the Phoenix Paints website that made me ask the question! I had hoped to use the small amount of Phoenix 2-part etch primer, but a quick peek at their site . . .
            #868851
            duncan webster 1
              @duncanwebster1
              <p style=”text-align: left;”>I think premixed etch primers have a shelf life, after which they don’t work,  so don’t use the leftovers from years ago</p>
              #868860
              Mark Rand
                @markrand96270
                I’d suggest etching it with ferric chloride or hydrochloric acid. Phosphoric acid, as used in etch primers will have little or no effect on 300 series stainless steels.
                #868861
                Paul Lousick
                  @paullousick59116
                  If it is a working model, the smoke box will get hot and most etch primers are not suited for high temperatures. Try car exhaust paint, available from auto accessory shops.
                  #868890
                  Hollowpoint
                    @hollowpoint
                    Shot blast then paint with VHT straight away. Like within an hour.
