Where to buy a 5mm bore, straight shank slotting saw arbor?
Home › Forums › Workshop Tools and Tooling › Where to buy a 5mm bore, straight shank slotting saw arbor?
  • #495025
    John Aitken
      @johnaitken84086
      I use slotting/slitting saw with a 5mm bore a lot and recently changed my mini mill so I had to lathe mt arbor down and I ruined it. Does anyone know where I can buy a metric strait shank saw arbor with a 5mm bore. Preferably the sank would be 6mm diameter or under.
      I could make one myself but a bought one will be far better and I don't want to make one.
      There is a company GenSwiss that makes them but they're $200 each and they want me to set up a USP collect account or something so I get charged whatever price UPS want to charge me when my parcel shows up.
      Any help would be appreciated.
      #19940
      John Aitken
        @johnaitken84086
        #495173
        Steviegtr
          @steviegtr
          I would not bank on a bought one been any better than you can make. I have quite a lot of them & most are not true.
          Steve.
          #495176
            The GenSwiss ones look mighty impressive surprise
            https://www.genswiss.com/sawarbors.htm
            … but I have to wonder if any ‘mini mill’ is good enough to warrant using them.
            Emgee
              @emgee
              Chris
              Using a 6mm shank to drive a 5mm hole cutter dose not provide much driving area of contact, better to go a bit larger to prevent slipping.
              As Stevie says probably best make your own, you only need to turn a 5mm shoulder on say an 8mm rod, drill and tap the end for a fixing screw and use a suitable size washer to attach the saw blade.
              If you want to use a 6mm shank as you only have a 6mm collet you can turn the shank down from 8-6mm for the length needed for the collet.
              Emgee
