I just wondered what your favourite milling fixture/holding device is? Perhaps you have a straight forward milling vice almost permanently mounted to the centre/one side of your table. Or maybe you have an angle plate, or a fixture of some sort – or maybe you just have a set of basic clamps/angles to go with your standard sort of 50pcs table clamp set.
So, what do you have, where do you have it (permanently/temporary?)
I currently have a plain old 5" Abwood swivel, bang in the center. I'm thinking of removing the swivel base (never used it) and moving it to one side but my table is worn in the center so it gets a little stiff at the edges which would get annoying.
I guess this applies to horizontal and vertical, and grinders – I'm not picky =)
Pictures speak a thousand words so if you've anything to show off that needs describing, pictures would be great!
Edited By Russ B on 06/04/2016 14:35:21
