What did you do today (2015)
Home › Forums › The Tea Room › What did you do today (2015)
Viewing 25 posts - 1,926 through 1,950 (of 3,154 total)
  • #197939
    mick70
      @mick70
      built my boy a tadpole from the atomic zombie plans.
      one for me with underseat steering is on my list of to dos.
      planning on second set of cogs halfway along run to large cog which is attached to small cog to get more power to back wheels.
      also making shorter crank arms for mine.
      hope link works never had luck putting pics up here, and kids are away so cant help.
      [URL=http://s1269.photobucket.com/user/steptash/media/aaaa1_zps5hkfns78.jpg.html][IMG]http://i1269.photobucket.com/albums/jj593/steptash/aaaa1_zps5hkfns78.jpg[/IMG][/URL]
      link to my build that modded to be my boys.
      http://forum.atomiczombie.com/showthread.php/9273-street-warrior-build?highlight=naughtyboy
      Edited By naughtyboy on 25/07/2015 11:01:06
      #197958
        @mike89748
        Roderick, I do love that term "tadpole" for a trike wit two wheels at the front. Two at the front makes sense – a Morgan 3-wheeler goes round corners very well, whereas a Reliant Robin…….well, enough said. Spent today fitting a 5-foot safety flag in the hopes of keeping more conventional road users at bay (I don't want my new cycling helmet tested), adding lights (two at each end to emphasise that it is wider than a bike), and in setting up the gears, which was initially a nightmare, but I now have all eight. I must say that assembly of a machine like this would be well within the capabilities of most ME readers, although anyone with an engineering background, amateur or professional, would be well advised to get the local bike shop to do the job. The standard of fits and tolerances was very good – just had to take a few thou off one of the bushes in the steering.
        #197959
          @mike89748
          Damn – I meant "without an engineering background". Typing fingers all thumbs today!
          #197960
          pgk pgk
            @pgkpgk17461
            #197967
            Boiler Bri
              @boilerbri
              Well it's been a really sunny day here in mid west wales. SO I decided to do a little bit more on my garden wall rather than play trains in Llandudno, watching the yachts and speed boats go by. Now the castle is showered by sunlight and the beer is flowing. Life just does not get any better. 😎. Are you jealous yet?
              It's going to pi/- down tomorrow! 😤so back to normal!,,,,
              Bri
              #197968
                Chain in a tube! That's an interesting idea. Looks fun.
                  @mike89748
                  Neil: The concept of chain in plastic tubes had me worried a bit first – thought it would create an unacceptable amount of drag – so I nearly assembled the thing without the tubes. Glad I didn't, because there doesn't seem to be any appreciable amount of drag, and the tubes keeps oil off your trousers as well as keeping muck and grit off the chain. Bear in mind that this machine is intended for light off-road use as well as on the road, and it makes sense.
                  #197998
                  Bazyle
                    @bazyle
                    Patience pays off. 2 days of allowing the penetrating oil to soak in and a grubscrew came out without damage to allen key or socket.
                    Need to part off 20 brass discs 1mm thick. That will be as much swarf as product – makes me whince but not worth making a smaller tool bit.
                    #198034
                    Bob Rodgerson
                      @bobrodgerson97362
                      After spending a few days in Northern Northumberland taking in the some of the Roman sites along the Wall I moved a little closer to Newcastle so that I had a decent WiFi connection and could upload this photograph of the starter motor I want to change the direction of rotation on. I know John asked me to post some pictures so he could verify that swapping the stator windings over would work. The photo shows the Stator wire running around the lower connection and the armature wire running to the brushes is the upper connection. There are two similar connections at.180 degrees to this.
                      The question which wires do I swap ?
                      #198044
                      Frances IoM
                        @francesiom58905
                        depends on how you intend to power the motor – can you live with the body connected to one terminal of power supply – if so then probably eaier to unfix the bonding between stator and the body, isulating this and feeding via a thick enough wire to some terminal block thus allowing you to reverse current in stator via a reversing switch
                        #198078
                        Bob Rodgerson
                          @bobrodgerson97362
                          Hi Frances, it looks to me that it might be easier to insulate the brushes by insulating the end cover somehow then cutting and sawing the wires over.
                          #198094
                          Bob Rodgerson
                            @bobrodgerson97362
                            I'm having second thoughts on reversing the rotation of the starter motor. I have a couple of gears that are a 2-1 reduction that I should be able to adapt to reduce the speed and reverse the direction of rotation. I just need some 1/4" alloy plate,1 plain & 1 top hat bearing and some spacers and I should be in business. Hopefully I can get it done in time for a trial run of the engine on Wednesday.
                            #198238
                            Rainbows
                              @rainbows
                              What did I do today: bought a big box of 1" lathe tools and morse adaptors.
                              Not bad for £20. Now just to get a lathe that could hold them.
                              #198246
                              bricky
                                @bricky
                                Just completed the cylinder of a Centaur gas engine.The cast iron casting was chilled at both ends and two opposite chilled seams ran from one end to the other.This has tested me and it's a good job I have little hair or I would have torn it out.The 1" boring bar was centered both ends but was flexing over the chilled seams giving an oval bore.The lapping could not remove this and I ended scraping these high spots and grinding them with a rocking motion over a 1" wooden dowell with grinding paste,and then finishing on the lap.Could someone tell me how much smaller the aluminium piston should be,it has cast iron rings.
                                Frank
                                #198247
                                  Posted by Rainbows on 28/07/2015 15:47:54:
                                  Should suit an Adept just dandy
                                    Posted by bricky on 28/07/2015 16:32:14:
                                    J.Could someone tell me how much smaller the aluminium piston should be,it has cast iron rings.
                                    Frank
                                    Make it about 0.003" smaller.
                                    #198254
                                    bricky
                                      @bricky
                                      Thank you for your rapid reply Jason.
                                      Frank
                                      #198276
                                      Rainbows
                                        @rainbows
                                        Posted by Neil Wyatt on 28/07/2015 17:02:09:
                                        Now if only I still owned one
                                        Also anyone wanna swap a lathe for a large box of tools?
                                        #198289
                                        Raymond Sanderson 2
                                          @raymondsanderson2
                                          New toy arrived yesterday well new to me. All seems to be in fine working order just need to locate a manual for it for reference.
                                          #198295
                                          Bob Rodgerson
                                            @bobrodgerson97362
                                            I will post some pictures later.Not Today but last night I made up a couple of gears for my engine starter so that I didn't have to reverse the rotation of it and also reduce the speed by half and give me more than enough torque for starting the 200cc flat twin.
                                            #198327
                                            Ian S C
                                              @iansc
                                              Hi Ray, useful tool, did you get the indexing plates, and maybe the tail stock centre? These are useful.
                                              Ian S C
                                              #198344
                                                I got an email today suggesting that our coverage of Adepts is causing golbal inflation in their value ;-0
                                                Raymond Sanderson 2
                                                  @raymondsanderson2
                                                  Posted by Ian S C on 29/07/2015 12:42:12:
                                                  Ian S C
                                                  No such luck Ian but Hare & Forbes do sell them. They had a set for sale about 2 yrs ago wish I had picked them up back then clearance stock they were.
                                                  #198349
                                                  David Clark 13
                                                    @davidclark13
                                                    Hi Neil Does that mean they have doubled in value to 2p?
                                                    #198355
                                                    Cornish Jack
                                                      @cornishjack
                                                      …causing golbal inflation…
                                                      mis-spelling there, Neil. Should be 'gullible', perhaps??cheeky
                                                      rgds
                                                      Bill
