SUSWE SU600A-2R2G1-B right mess
Home › Forums › Electronics in the Workshop › SUSWE SU600A-2R2G1-B right mess
  • #859567
    tatler
      @tatler
      Help
      i have one of these VFDs and set it up but it all over the place.
      The wiring is correct for both input(R L1) and output(UVW).
      So connected a rotary two way switch to X1 com  and X2 com ( this has 1 0 2) and has 12connections so i connected a com to 1 and 3 on the switch via a bridge. X1 to 2  and X2 to 4 on the switch  which i think is ok.
      When i switch the motor on the motor runs at only 10hz and in reverse at full 50hz straight away  the potentiometer has no effect and does not control the speed.
      Also when the motor is stopped the display shows 49.9 which i presume is the HZ.
      Can any of my fellow colleagues help a hopeless electronic newby.
      Thanks in advance to everyone.
      joe
      #859657
      Andrew Tinsley
        @andrewtinsley63637
        Sorry I can’t help, but it does reflect on the well known, poor documentation, of many cheap Chinese VFDs.
        I have in the past, purchased major brand VFDs, second hand, at not much more than a cheap Chinese VFD. At least you can then access excellent documentation. Unless you are an experienced VFD user, I would recommend steering clear of the generic Chinese VFDs. There are quite a few pleas for help on the forum, from people that are in your situation.
        Andrew.
        #859661
        John Hinkley
          @johnhinkley26699
          I have no experience with vfds giving 380v output (all the ones I’ve had were 220 to 220v single to three phase.  You say “it has been set up”. By whom? If by you, I would suggest resetting it to the factory settings and starting again, altering as few settings as possible and one at a time. There is a specific parameter to carry out the reset –  from memory, I think it was P13 but I’m not 100% sure without consulting the manual.
          I used to start with max and min frequency settings, then the acceleration and deceleration times. Finally I’d finish off by setting the parameters for a remote on/off and forward/reverse switches and speed control potentiometer, if fitted.  I agree that most generic Chinese documentation is pretty poorly translated, but it’s not an impossible task.
          Do you have a link to the manual you can share?
          Good luck,
          Bazyle
            @bazyle
            The starting point should be to run just off the built in switches without anything additional. However check manual first too as one of mine needed an on/off switch connected to two terminals before doing anything (probably a safety measure).
            So reset, remove switch and start from scratch.
            #859677
            tatler
              @tatler
              Thanks fior this its driving me NUTzzzzzzzzzzzzzzzzzzzzz .
              played around again and now it runs in forward and can be  controlled by the potentiometer pot  but wont reverse.
              Checked continuity form X2 to the switch and that working ok i do have a manual i can upload if anyone can make sense of it to help me out??
              joe
              #859681
              DC31k
                @dc31k
                A search finds:
                https://eshop.frelion.cz/wp-content/uploads/2024/03/SU-600.pdf
                It would be useful if the OP would draw us a pencil sketch of how the device is wired up and give us a list of the current parameter settings (or say decisively which ones are altered from factory default). Otherwise, we are guessing.
                It needs a lot more that typing three small words, “set it up”, to start the solution to this problem.
                #859694
                Bazyle
                  @bazyle
                  I think you have to enable reverse – again a safety control on one of mine. Try parameter F0.12
                  #859778
                  tatler
                    @tatler
                    thanks to everyone ,
                    played around with it and now it runs forward from an external 2way switch connected to x1, x2 and comm.
                    it also can be controlled from the potentiometer, but the reverse wont run  but the rev light is on and the potentiometer reading is 0.0.
                    Checked the book and both the F forward and reverse values are set as per it says but nothing.
                    Any one ???
                    #859825
                    Bazyle
                      @bazyle
                      Did you set F0.02 to 1 and F0.03 to 3?
                      #859873
                      tatler
                        @tatler
                        hi yes set up as per booklet when i  put F0.03 to 3 it wont run so put it back to 0 and it runs.
                        I dont seem to be getting anywhere with this unit.
                        Emailed the suppliers but they not replied.
