Unimat milling tables
Home › Forums › General Questions › Unimat milling tables
  • #425531
    Former Member
      @formermember19781
      #26799
      Former Member
        @formermember19781
        #425567
        Emgee
          @emgee
          Hi Bill
          SL milling table is 127×76 11mm thick with 3x8mm Tee slots that are 3×13 at base.
          There are 4x6mm fixing holes counter bored 11mm diam for 6.9 depth, starting at 24mm from end then 50 from end (so 26mm centres)
          2nd row 25mm centres from those above. So 24x26mm rectangle with holes at corners.
          Will PM you about a drawing.
          Emgee
          #425582
          Emgee
            @emgee
            Hi Bill, check your Inbox on the top of page.
            Emgee
            #425839
            John Olsen
              @johnolsen79199
              Just checked the dimensions given by Emgee above against my own Unimat 3 milling table. That table would work on my Unimat 3, even though the mounting holes are a slightly different spacing. It would work because the cross slide of the Unimat 3 has a T slot, so the slightly different hole spacing would not matter. The table mounts either across or along using two of the holes.
              There does seem to be a difference in the T slots. Mine are 4mm where the ones given by Emgee are 3mm, eg both the length of the stem of the T and the thickness of the top of the T. So my T nuts would not fit into Emgee's T slots. This would only matter if you already have the same T nuts as me.
              Former Member
                @formermember19781
                #425870
                  The only thing if the hole spacing is different it that it may not fit on teh bracket that allows it to be used as a drilling table around the column as that has fixed hole spacing.
                  #425910
                  Former Member
                    @formermember19781
                    #426064
                    Roger B
                      @rogerb61624
                      They are still available, but not cheap.
                      Best regards
                      Roger
                      #426065
                      Former Member
                        @formermember19781
