Toolpost question
Toolpost question
Home › Forums › Workshop Tools and Tooling › Toolpost question
  • #456753
    Mark Braham
      @markbraham75264
      I have a myford ml7 and thinking about a qctp, will a multifix type A fit or will i need the smaller Aa, i like the 40 point system, but any other recommendations greatly accepted. Cheers Mark
      #19656
      Mark Braham
        @markbraham75264
        #456869
        David George 1
          @davidgeorge1
          Bump someone will answer.
          #456870
          Steviegtr
            @steviegtr
            Do you have a picture or link to the one you want. I have fitted the 250-111 or size 2 to my S7 which I guess will have the same compound. The reason was because I had quite a lot of cutters that were 14mm + To fit this one I had to get 4mm ground off the top of the compound & then I machined 4mm from the underside of the holders so I could get them low enough. All great now & glad I did the conversion. Look at you tube ,I think Steve Jordan did one on his ML7. The one I have will only take 1 holder at a time though. Just thinking about it , does your compound rotate for angle cuts or is it fixed.
            Steve.
            #456874
              Posted by Steviegtr on 12/03/2020 22:42:32:
              Do you have a picture or link to the one you want. I have fitted the 250-111 or size 2 to my S7 […]
              Possibly some confusion there ^^^, Steve
              For reference: The original [Swiss] Multifix Quick-set is shown here: **LINK**
              http://www.lathes.co.uk/multifix/
              Mark is presumably looking for one of the modern clones.
              Steviegtr
                @steviegtr
                Posted by Michael Gilligan on 12/03/2020 23:15:33:
                Ah I did wonder. Doh.
                Steve.
                #456886
                Nick Hughes
                  @nickhughes97026
                  I have the Aa size on my S7.
                  The standard A size tool holder will not go low enough, BUT the genuine Multifix made some special A size tool holders for the Myford 7 lathes and I think the set was designated Am.
                  Nick.
                  Edit:- Even when using the Aa size with insert tooling, the 8mm square shank tools only just go low enough, to be on centre height (I use 10mm square, milled down to 8mm high, leaving them 10mm wide).
                  Edited By Nick Hughes on 13/03/2020 00:07:28
                  #456918
                  Mark Braham
                    @markbraham75264
                    Found all the dimensions online and ordered the Aa size as its within spec for the toolpost base to chuck centre, chose the german multifix although i believe they all come from china. Anyway its a nice birthday present to me from my wife .
                    #456923
                      Wishing you a Happy Birthday, Mark yes
                      Please let us know what you think of it.
                      Mark Braham
                        @markbraham75264
                        Jusr had a lovely message from PeWetools in germany, telling me his story about his multifix toolpost and the devopments using china as his supplier, was a very i interesting read.
                        #456931
                        Lee Rogers
                          @leerogers95060
                          I'll second that and please do post and let us know how you get on with it . I'm a Drummond user and tool post rigidity is key to getting these little lathes to work well. The M type is more capable in some respects than an ML7 but a rigid set up is vital.
                          #457104
                          Nick Hulme
                            @nickhulme30114
                            I looked at Multi-Fix and found that almost none of the angles I wanted to set tools at were catered for by the 9 degree increments.
                            #457114
                            Mark Braham
                              @markbraham75264
                              You can still turn the whole post if you wish, unless you pin it in position. Which obviously needs to be very carefully done to ensure its parrallel to the chuck.
                              #457126
                              Joseph Noci 1
                                @josephnoci1
                                Posted by Mark Braham on 13/03/2020 10:08:51:
                                Interested to see what PeWetools had to say – My experience with the Chinese Create Tool holders was excellent – Instead of repeating it all , if interested the relevant posts are HERE
                                Peruse the whole page of posts, but maybe from 12/07/2017 is more to the point
                                Joe
                                Edited By Joseph Noci 1 on 14/03/2020 11:53:58
