Source of milling cutters post Arceurotradw
Home › Forums › Workshop Tools and Tooling › Source of milling cutters post Arceurotradw
Viewing 15 posts - 1 through 15 (of 15 total)
  • #864619
    Mike Crossfield
      @mikecrossfield92481
      Now that Arceurotrade has very sadly disappeared, is there an alternative source of reasonably priced carbide milling cutters?
      #864625
      Baz
        @baz89810
        Cutwell and Shop APT for starters.
        #864632
          As this site seems to now have adverts for Aliexpress then I can’t see why I should not mention the Xuhan brand ones I have been buying via them. They have gone up from the £2 I was paying for a 6mm cutter a couple of years ago to about £5 now but still a reasonable buy for general use coated for steel and uncoated non ferrous cutters.
          APT  have always been cheaper than ARC on the small sub 6mm sizes so I use them too plus they do 3-flute that Xuhan don’t do many of. Between the two it’s hard to see a difference in performance and tool life. They
          https://xuha-cutting-tool.aliexpress.com/store/5041252?spm=a2g0o.detail.0.0.b381SEUDSEUDZc
          #864638
          Mike Crossfield
            Excellent. Good info.
            Thanks to both of you.
            #864646
            JA
              @ja
              Drill Services (Horley) https://www.drill-service.co.uk/
              All types of milling cutters and reamers. The common sizes are sensibly priced and they offer a next day delivery (depending on your local post office).
              JA
              #864650
              Geoff Rogers
                @geoffrogers81118
                APT are my go-to place for cutting tools.  Very big range, with lots of sensible prices plus some that make you say ‘how much?’
                GR
                #864660
                Roderick Jenkins
                  @roderickjenkins93242
                  I’ve used Rennie in the past e.g.
                  Rennie 6mm Carbide 3 flute endmill
                  Rod
                  #864678
                  Wingo
                    @wingo
                    APT give good service as well as good products. The only cutter I had problems with (large 16mm) was instantly replaced with next day delivery. Can’t recommend higher than that.
                    #864679
                    Baz
                      @baz89810
                      APT also sell carbide tips in two’s to save you having to buy a standard box of ten. Look under “carbide tips for hobby use”, second item down in the left hand menu. Of course they are slightly more expensive per tip but only by a couple of pennies.
                      #864686
                      Hollowpoint
                        @hollowpoint
                        There’s also an abundance of new old stock cutters on ebay, many of which are very high quality from the very top brands. You’ll likely pay a little bit more, but they will likely last longer.
                        #864688
                        jimmy b
                          @jimmyb
                          I have had some good quality carbide endmills ftom Temu. Very good quality and reasonable price.
                          The HSS ones have been total rubbish
                          Jimb
                          #864817
                          Juddy
                            @juddy
                            #864839
                            HOWARDT
                              @howardt
                              https://www.ewequipment.co.uk/
                              Look out for frequent sales.  Have used them for some years.
                              #864847
                              Graeme Seed
                                @graemeseed34272
                                Hi, my preferred supplier is Tracy Tools. Always top quality. Many items have Sheffield makers stampings, so they seem to source older quality manufacturers. Graeme Seed.
                                #864911
                                Mike Crossfield
                                  Thanks everyone.
                                  plenty to try.
                                  Mikr
