Parting off
Parting off
Home › Forums › Beginners questions › Parting off
Viewing 12 posts - 51 through 62 (of 62 total)
  • #864600
    Mick B1
      @mickb1
      Troubles I’ve had have usually been due to a blade off-square.
      It’s as well to part off over-length and maybe have a set of soft jaws available for light facing cuts if you get a bowed face.
      #866404
      old mart
        @oldmart
        I just parted off a 50mm diameter bar of meehanite cast iron, it was the nicest parting off I have ever done.
        #874228
        Geoff Dunsby
          @geoffdunsby15757
          Hi,
          Parting off is one of those jobs that goes brilliantly well or fails completely.
          Often overlooked are worn chuck jaws. Most lathe jaws wear into a taper over time getting wider nearer the tool post end.
          The part becomes unstable in the jaws particularly when parting because of the radial loading.
          The jaws can be reground or machined (A good TC tool needed) by making some wedges to fit between the jaws to simulate to presence of a workpiece in the jaws whilst maintaining a aperture wide enough for the cutting tool to machine the jaws.
          Good luck.
          #874468
          David George 1
            @davidgeorge1
            I have aa rear part off tool which is set on center height and uses a interchangeable tip tool. It is solid and the blate can be easily unlocked and slid in or out and will easily part 3 inch diamiter with no problems as long as I use lubrication as well. 20261004_160148
            #874479
            derek hall 1
              @derekhall1
              I have made the rear parting off tool to the George Thomas design for my Super 7 and I hate to say this, I do struggle with the performance of such a tool designed by the “master”.
              I have the 1/16 inch wide blade on one side and 3/32 on the other i.e. to the original design. All dimensions have been checked, both the blade are square to the axis, upright, sharp and on centre.
              The main problem I have is that the 1/16 inch parting blade protrudes about 19mm from the square mounting block and the 3/32 wide parting tool protrudes 32 mm. The tool protrusion looks way too much for parting off.
              The whole thing just looks very unstable and precarious. The design I think allows the user to part off to about 2 inch diameter, but it would be quicker and less stressful for me with a hacksaw to be honest.
              All the best
              Derek
              #874490
              Geoff Dunsby
                @geoffdunsby15757
                Hi Derek
                I agree with you that the stick out seems excessive for such a narrow parting tool.
                To get that to work everything need to be spot on and delicate feed speed is needed.
                I assume you are parting a steel part 2″ in diameter? Is it solid?
                I’d want to use a 3mm wide blade, possible a carbide insert with a deep holder to get enough support.
                I think I would resort to the bandsaw or hacksaw.
                #874498
                  Is there no way the tools can be slid in and out of the holder? While I have used such narrow tools at those stickouts when the job required in cases like that I start off with less protrusion and then slide a bit more out once the cut is well underway. It certainly stops the tool wandering sideways.
                  #874505
                  Howard Lewis
                    @howardlewis46836
                    I have been using a parting blade in a rear mounted toolpost for so long, I cannot remember when, probably thirty years or more.
                    For the past 23 years the same holder and blade have been mounted in a shop made 4 way indexing rear toolpost, that cosmetically imitates the front toolpost.
                    The blade has no top rake, and is therefore horizontal. Dig ins do happen, very occasionally, but not  disastrously. Just back out and try again.
                    This set up is so effective that often a power cross feed of 0.002 – 0.003″/rev is used without problems.
                    But keep things as rigid as possible, so minimum stick out for blade and holder, and avoid having an angled front to the blade.
                    If lubrication is used, it either a drip feed of soluble oil, or engine oil applied with a brush.
                    H T H
                    #874517
                    bernard towers
                      @bernardtowers37738
                      Jason I think you will find that the blade slots are angled so sliding the blade in and out changes the height/stick out.
                      #874529
                      Geoff Dunsby
                        @geoffdunsby15757
                        I think the bit advice with the top angle is right. If your machine has a bit of power a slight negative angle helps with stopping digging in. Particularly with softer materials.
                        the real killer here is lack of rigidity. Some mini lathes lack both power and rigidity and make parting off a real pain.
                        #874534
                          Oh, it’s one of those types.
                          I which case can the height be altered to allow for less stick out but still put the tool on ctr. Might need a second holder or packer if you want to do deeper cuts.
                          #874564
                          duncan webster 1
                            @duncanwebster1
                            Don’t be tempted to grind top rake onto a horizontal blade of this type. As soon as the cutting edge is below the top of the unground tool it is thinner, so if you go deeper than the ground bit it tends to jam
