Stepper drive for a Lathe Cross Slide. Issue No.246
Home › Forums › Model Engineer & Workshop › Stepper drive for a Lathe Cross Slide. Issue No.246
  • #255216
    Victor Higgins 1
      @victorhiggins1
      Under the heading , The Electronic Lead Screw X Axis: It states that the Z is parallel to the axis of the lathe spindle, the same as on a mill, and X runs at right angles to the axis of the lathe spindle. i.e. the cross slide. Is correct?
      #38371
      Victor Higgins 1
        @victorhiggins1
        #255253
        Martin Connelly
          @martinconnelly55370
          Yes, z axis positive direction is away from the chuck. X axis positive is towards the operator for a front tool post.
          Martin
          #255360
            Think of lying your mill on its back, so the column (z) becomes like the bed of the lathe.
            #255365
              … and if you want to control movement in the Y axis, you need a vertical slide.
              John Stevenson 1
                @johnstevenson1
                Posted by Michael Gilligan on 12/09/2016 00:24:09:
                Lathe has X, Z, A and C
                #255367
                  John,
                  I was referencing Neil's analogy.
                  not done it yet
                    @notdoneityet
                    Ooh-er! I'm in trouble, my 2 axis dro for my lathe only has x and y axes.
                    Anyone seen a 2 axis dro with z axis plus one other?
                    #255390
                      Posted by not done it yet on 12/09/2016 06:01:36:
                      Various reasonably priced solutions are available:
                      Sticky Labels; Marker Pen; etc. devil
                      P.S. … Yuriy has it sussed
                      http://www.yuriystoys.com/2014/01/touchdro-coordinate-system.html
                      Edited By Michael Gilligan on 12/09/2016 07:54:47
                      #255404
                      Mike Poole
                        @mikepoole82104
                        Lucky we are not robots having to calculate the tool path in multiple coordinate systems, back in the 80s this challenged the computing power of a robot and could have some odd effects.
                        #255416
                        John Stevenson 1
                          @johnstevenson1
                          And to muddy the waters even further when you swap from Absolute to Incremental the X, Y, Z changes to U, V, W
                          wink
