Small powerful springs
Home › Forums › General Questions › Small powerful springs
  • #153142
    John Stevenson 1
      @johnstevenson1
      So you now need a Zebedee avatar ?
      #153143
      Rick Kirkland 1
        @rickkirkland1
        BOING! said Florence.
        Rick
        #153152
        Gordon A
          @gordona
          "Time for bed" said Zebedee !!
          #153165
          Gordon W
            @gordonw
            Some HGV's have rubber springs, these are fitted in a sort of V formation and are in compression and torsion. Often found on cement mixer trucks and bin lorries. I think may have been used on rail vehicles. These would be simple to make and give better performance ? Can't remember any details but should be on google.
            #153168
            Bob Brown 1
              @bobbrown1
              The shock absorbers or to give them their correct name dampers in a lot of cases have bump stops fitted to the damper shaft which in effect are a progressive spring which are designed to increase the spring rate for a small movement (travel) of the suspension. Although some are rubber most or at least the better ones are a foam polyurethane. May be some stock polyurethane could be machined into a conical shape to give a progressive spring rate to allow for differing weights, may well work for passenger carriages as well.
