Silver steel
Silver steel
Home › Forums › Beginners questions › Silver steel
  • #96930
    Terence Yates 1
      @terenceyates1
      Hi all, I need to replace the the countershaft on my Myford ML7 Tri-Leva. A nice piece of 3/4" silver fits a treat. I have allready replaced the bushes and reamed them. Now can I use it as is, or have i got to heat treat it and if so how?
      Terry.
      #6309
      Terence Yates 1
        @terenceyates1
        Hardness
        #96932
        Tony Pratt 1
          @tonypratt1
          Sliver steel as is will be fine.
          Tony
          #96935
          Terence Yates 1
            @terenceyates1
            Hi Tony, thanks for that. I thought it would be OK, but my son who is an Engineer thought it should be harder.
            Terry.
            #96939
            Tony Pratt 1
              @tonypratt1
              Hi Yak, to elaborate, you will be in a world of trouble if you try to harden Silver Steel for this application, ie the shaft will bend and you will get scaling on the outside. In industry a shaft like this would be turned oversize, hardened and then ground to size if you really wanted to heat treat it, but as Iv'e said soft state Silver Steel will be fine.
              Tony
              #96992
              Ian S C
                @iansc
                You could use a lower carbon steel than silver steel, 4140 would be more than adiquate, thats proberbly better than for instance, the shaft in the motor on your lathe. Ian S C
                #96996
                colin hawes
                  @colinhawes85982
                  You don't need tool steel for a countershaft mild steel would do .I would keep the more expensive silver steel for making tools. Colin
