Hydrostatic Transmission by Mike Tilby
Home › Forums › Model Engineer & Workshop › Hydrostatic Transmission by Mike Tilby
Viewing 15 posts - 1 through 15 (of 15 total)
  • #861703
    Ronald Wagner
      @ronaldwagner57800
      I was very interested in the recent article by Mike Tilby regarding hydrostatic transmission, in large part because hydraulics have always been a bit of a mystery to me.
      I was trying to be sure I understood the fundamentals and was being caught up short by the diagram in “Box 1”.  I finally discovered why things were not adding up correctly.  I really would have liked that diagram to include the fundamental equations, but I suppose maybe those aren’t necessary for the learned readers.
      What I concluded was that the text included in the box was correct, but the diagram’s final output value was not.  Assuming the pressure in the large cylinder is 255 psi and the diameter of the cylinder was 5in, then the output force should be:
      F = p * A   and   A = pi * ( 5 / 2 )^2 or 19.63 sq in
      F = 255 * 19.6
      F = ~5006 lbs and not the 1265 shown in the diagram.
      This then agrees with the text’s statement of 100x input force of 50lbs
      Ron
      #861704
      Ronald Wagner
        @ronaldwagner57800
        I perhaps should have made clear that I did appreciate the article – I’m just a little slow on my math.
        And if it saves anyone some typing, there are the youtube links mentioned in the references:
        #861734
        noel shelley
          @noelshelley55608
          Don’t recall the article BUT your 5006 pounds force is correct for a pressure in the cylinder of 255psi. But where did the 255 come from ? A simple lever and small cylinder ? Small cylinders and lever type pumps will raise 10,000PSI with fair ease, so your 5″ cylinder will produce 87.5 tons – as just another example. I often use a 3″ piston jack that is rated at 25 tonnes.  Noel.
          May be I should point out that whilst the piston may produce a force of 87.5 tons the piston rod may well not be able to take this load. Ordinary systems often work at 2500psi for power operation, eg tractors etc. From memory, flow in gallons/min  X  pressure in PSI divided by 1428 gives the HP required.
          Flow is the speed at which the system will operate.
          #861748
          Ronald Wagner
            @ronaldwagner57800
            Yes, in the article, the 255psi was generated with a much smaller, lever actuated cylinder.
            I’m away from the article right now, but the diagram was something like a 1:5 lever acting on a cylinder.  A 10# force on the lever results in 50# on the cylinder.
            The cylinder had a 0.5″ diameter, for an area of .196 sq in.  50/.196 = ~255psi
            #861797
            noel shelley
              @noelshelley55608
              You seem to have got it ! The numbers add up and would work for a small hand pump on a model but for a small hydraulic jack a mechanical advantage of 15 would be more likely and on a bigger one 25. When one then adds the hydraulic advantage one soon starts to measure in tons. Noel.
              #861820
              duncan webster 1
                @duncanwebster1
                I once tried to get a loctited wheel off its axle using a hydraulic jack. It wouldn’t budge so I put a length of scaffold pole over the handle and leaned on it. The cylinder burst, depositing me on the floor
                #861871
                martin haysom
                  @martinhaysom48469
                  the relief valve should have stopped that happening
                  #861888
                  noel shelley
                    @noelshelley55608
                    Small vertical hydraulic jacks do not tend to have a relief valve – relying on the supplied handle as being able to keep the device within it’s design limits. When you reach for the extension tube/bar then all bets are off . The risk of a simple overload valve letting go with the load on and someone under the load is a bigger risk. Even the cheap trolley/floor jacks have a relief valve. BUT we all know that such a device can easily be wound in. History is full of tales of disaster following the unauthorised meddling with valves !
                    Steam engineers talk in tens or hundreds of PSI, Hydraulic engineers talk in thousands of PSI. If Duncan would care to give figures for the pump piston diameter and the mechanical advantage, plus a clue as to the force he was applying, it might frighten him and be interesting for us ?  Noel.
                    PS the process of hydroforming is interesting.
                    #861958
                    duncan webster 1
                      @duncanwebster1
                      I’ve long since dumped the split cylinder and have no idea of the mechanical advantage. The only name on the outer case is Sprint 2, and the ram is 24mm diameter. If it were a 1te capacity this would equate to 22 MPa, about 3300 psi, pro rata for higher capacity,  I probably doubled the length of the lever, and had my full (not inconsiderable) weight on it
                      #871510
                      Mike Tilby
                        @miketilby23489
                        Hi Ron, I’ve only just seen this thread. I’m very sorry to have included such a glaring error and for the confusion that it caused. As has been said already it should have stated that the force is 50 lb x 100 = 5,000 lb or 2.2 tons. At least the text in the box was correct, the area of a circle 5” diameter being 100x that of a circle 0.5” in diameter.
                        The one consolation for me is that this thread shows that at least one person actually read the article.
                        Regarding your point about more detail, I find it difficult to judge how much detail to actually include in things like this and would be happy to try to answer any questions. Also, perhaps I should say that the example was just meant to illustrate the principal with no pretence to represent any actual machine.
                        I’m glad the error has been pointed out – I’ll ask Neil to publish a correction, on the principle of better late than never.
                        #871608
                        Charles Lamont
                          @charleslamont71117
                          Does anyone know of a model with home-made hydrostatic transmission?
                          #871612
                          Mike Tilby
                            @miketilby23489
                            The only model with working hydrostatic transmission that I’ve come across is a model tractor with working hydraulics that was built by a Godfrey Greeves. I have not seen this described in ME or ME&W but Neil Wyatt told me his tractor was featured twice in Exhibition reports.
                            I saw the model in the recording of a talk that Mr Greeves gave to SMEE a while ago and it was a very impressive model. The recording is still available for members of SMEE. I too have wondered if anyone else has tackled a similar model.
                            #871649
                            Bazyle
                              @bazyle
                              Godfrey was a member of the St Albans club and had his model on the club stand at the Pickets Lock exhibition I think. It used a swash plate pump and although it had an IC engine it also had an electric drive for ease of demonstration. I’m not sure what happened to the model but will ask around the club.
                              #871671
                              Clive Foster
                                @clivefoster55965
                                Hi Mike
                                Know exactly what you mean about deciding level of detail for articles. I’ve got at least half a dozen part done attempts covering different subjects abandoned because I couldn’t combine general audience readability with the level of detail I felt desirable for proper understanding. The reports I used to write when employed as a scientist / R&D engineer were not good training for the ME&W audience!
                                Dunno if the magazine typesetters can handle it but one approach that looked very effective to me was to separate out the maths and higher detail into a separate side column. That left the basic article very readable for would who only wanted a reasonable overview of what was going on without the great attention needed when maths and detail are embedded. I found having the math and supporting detail hived off also made them easier to follow. The ones in  that format let me easily read through the main text with normal casual attention first to find out how it all fitted together. Having gotten the basic overview first made following the detail vastly easier. Especially as the detail stuff was fairly well aligned with the easier to understand overview.
                                Sorting the alignment must have been a right pain.
                                For my own purposes I’d sometimes do my lab books with descriptive text on one page and maths et al on the facing one. Totally against the firms rules. Which worried me not at all.
                                #871694
                                duncan webster 1
                                  @duncanwebster1
                                  Neil now seems open to using weblinks in articles, perhaps the top level description could be in print and the sums as a link. It would also make transcription errors less likely.
