Uniflow engine
Uniflow engine
Viewing 2 posts - 1 through 2 (of 2 total)
  • #861929
    AStroud
      @astroud
      I finished my bump valve uniflow engine and gave it a first run. It needs 50 psi to start and during a run it seems to find a resonance spot and speeds up alarmingly. It has reinforced my faith in Loctite as the crankshaft and 3 piece conrod are assembled just using 638. I didn’t realise these engines run at such high speed otherwise I would have given more thought to balance, as it is it needs clamping to my hefty surface plate to stop it taking off.
      https://youtu.be/wxMrnPKdZP0
      #861942
        It’s running well, yes they are fast little bu**ers
