Annealing extruded acrylic
Home › Forums › Materials › Annealing extruded acrylic
  • #862086
    Mick Bailey
      @mickbailey28509
      As a side project I’ve machined up some guitar pickup mounting rings in 4mm extruded acrylic sheet (PMM). Size is 4″ x 2 1/8″ and with the cutout there’s about 3/8″ border. Drilled and countersunk on the corners.
      Is there any mechanical advantage in annealing them? Cast rather than extruded would have been a better choice, but I’ve used what’s to hand.
      If annealing is necessary I’ll use my toaster oven with a Variac and give them a few hours at 85 degrees C.
      #864920
      Mick Bailey
        @mickbailey28509
        Annealing in this particular instance wasn’t any benefit as far as I can see. There’s some unwanted shrinkage and no discernable change in strength.
        I think the main advantage is reducing stress cracking with exposure to some hydrocarbon fluids, not relevant with these parts. I have experienced this with using solvent degreaser on an acrylic mororcycle tail light lens years ago – the plastic crazed instantly throughout its thickness and showed all the stress lines quite clearly.
        #864949
        bernard towers
          @bernardtowers37738
          I have annealed some ext/cast acrylic with mixed results. items with quite a bit of machining on them(sharp corners/holes/threads etc) seem to benefit more by releasing the stresses built up by machining. I do mine in the oven at about 80 degs
        Home › Forums › Materials › Topics
