Scrappy Haul (50 HSS Pieces)
Home › Forums › Workshop Tools and Tooling › Scrappy Haul (50 HSS Pieces)
  • #497033
    Lee Jones 6
      @leejones6
      So I went a bit giddy today at the scrappy (only went for a bit of aluminium).
      Even if I never use this stuff, I still had a good time foraging.
      £35 though. Might go every week. laugh
      What are your thoughts?
      #19953
      Lee Jones 6
        @leejones6
        #497037
        Baz
          @baz89810
          If you have a vertical and horizontal mill they will fit it’s not a bad haul. Are they all sharp?
          #497038
          Nigel Bennett
            @nigelbennett69913
            What a haul!
            Whatever you do, don't try to use the large end-mills by holding them in a lathe chuck. Cutters that size are nasty, horrible, malevolent things that will try to remove parts of your lathe, job and anatomy with distressing results unless they are properly held. You will need a proper collet chuck and a big milling machine to use them.
            Don't ask me how I know…
            #497045
            Lee Jones 6
              @leejones6
              Yes, I have a collet chuck and a mid-sized floor standing milling machine.
              No plans to put any of the cutters in the lathe.
              I don't have a horizontal milling machine, but I do have an R8 arbor that takes them.
              Not sure if using the larger milling cutters as slitting saws is such a good idea though.
              #497047
              Brian H
                @brianh50089
                Definitely a good buy.
                #497059
                Bazyle
                  @bazyle
                  Lucky man to have a scrap source that gets that kind of stuff in and lets it out again.
                  #497061
                  Lee Jones 6
                    @leejones6
                    I think metal is metal to them TBH.
                    Last time I visited they sold me 3kg of barely used carbide inserts.
                    Shame not many of them fit my tooling, but it's the thought that counts.
                    I'll dig out a picture.
                    Edited By Lee Jones 6 on 21/09/2020 15:23:58
                    #497062
                    Lee Jones 6
                      @leejones6
                      It's all too big for the holders I have (and I have some pretty big holders)!
                      #497066
                      Baz
                        @baz89810
                        You can always silver solder the tips onto a bit of steel bar, when they are blunt or ground beyond use a quick blast with the propane torch and you can put a new one on.
                        #497069
                        Lee Jones 6
                          @leejones6
                          It's something I would consider if I didn't already have more carbide than I know what to do with. My lathe came with a massive plastic box of the stuff.
