Quorn Mk3
Quorn Mk3
Home › Forums › Workshop Tools and Tooling › Quorn Mk3
  • #427750
    Gareth Jones 9
      @garethjones9
      I notice that Hemingway are now showing a Mk3 version of the Quorn tool and cutter grinder. It is claimed to be easier to set up for grinding and easier to build. Anyone taken a closer look at the Mk3?
      Thanks,
      Gareth
      #19454
      Gareth Jones 9
        @garethjones9
        #427756
        Steve King 5
          @steveking5
          Nope but i will now
          Thanks
          #427767
            Posted by Steve King 5 on 06/09/2019 11:15:58:
            Nope but i will now
            Thanks
            +1
            … and here's what I found: Quorn – The Mk3 Advantage!
            Ref. **LINK**
            http://www.hemingwaykits.com/acatalog/Quorn__Mk3__T_C__Grinder.html
            Much of which looks like very sensible product development [*]
            [*] … one statement is sure to prompt some debate though !!
            Hardened and ground ER extension chucks and collets, readily and cheaply available, are used to retain both cylindrical and rectangular items with great precision.
            devil​​​​​​​
            #427794
            Clive Hartland
              @clivehartland94829
              Plus £61 for the detailed build instructions.
              #427798
              ega
                @ega
                As a long term user I was interested in this.
                The motor seems new ie not the Parvalux which used to be supplied. I couldn't see anything about speed control which seems a shame.
                I would like to see more information on the website before buying the £61 "card".
                #427799
                  Now using ER collets – that will upset some!
                  " Frankly, if you've been thinking about building a Quorn for your own workshop – you've done particularly well to wait until now! "
                  ROFL!
                  Mind you Hemmingway have had those patterns for almost as long as some people have had their castings…
                    Posted by Neil Wyatt on 06/09/2019 14:24:22:
                    …. especially the "readily and cheaply available" variety thereof.
                    Clive Brown 1
                      @clivebrown1
                      Posted by ega on 06/09/2019 14:20:37:
                      ________________________
                      Didn't the original design deliberately give a fixed top speed within the maximum for the largest wheel and Prof. Chaddock gave some words of warning on this, including the type of motor to be fitted. Also, one function of the belt guards on the Mk. 2, which was intended for commercial use, was to discourage non-standard pulleys.
                      The new tooth rest looks as if it might be a useful improvement over the original rather awkward affair.
                      Can't see just how the "unholy" circular tee-slot has been dealt with though.
                      I think the appeal of the Quorn to the general modeller has reduced since its introduction in the '70's with the availability of fairly cheap cutters, which can be treated as "throw-aways" and TC inserts. There are also simpler T&C grinder designs available.
                      Also, the 4 flute end-mills on the market now mostly seem to have one cutting lip drawn over-centre, a feature that I've not found a way of deaing with on my Quorn without damaging the other lips.
                      Edited By Clive Brown 1 on 06/09/2019 15:38:07
                      #427819
                      Emgee
                        @emgee
                        Nothing new about using ER type collets on a Quorn, been doing it for years with an Emco ER25 collet chuck fitted to an MT2 arbor and another with a 1" shank that fits direct to the head.
                        Interesting to know some simpler method of setting is available, perhaps someone will share the secret.
                        Emgee
                        #427836
                        Mark Rand
                          @markrand96270
                          I've got a second-hand set of Quorn castings seasoning on the shelf. One new addition I've made to the set is a set of Martin Models 5C tool holder and spiralling head and tailstock castings with a 2 1/2" height, instead of the standard 2" height. Since I've got a pretty full set of Imperial and metric 5C collets, with square and hex as-needed, I felt that this would be a good modification.
                          Even with shipping from the USA, the price was reasonable.
                          Still got to get around to making it though…
