QCTP problems
QCTP problems
Home › Forums › The Tea Room › QCTP problems
  • #35600
    OuBallie
      @ouballie
      Thus guy really is getting grief
      #426061
      OuBallie
        @ouballie
        I would bin that QC
        That bar material that looks of dubious quality.
        Will be interesting reading responses.
        Walking nearly a mile now and feeling good ✔️
        Geoff – Soon back in the saddle.
        #426080
        old mart
          @oldmart
          I think you will have to explain what you are talking about, so far it doesn't make sense.
          #426084
          David Davies 8
            @daviddavies8
            Follow the hyperlink to watch some antics while attempting to part off!
            #426087
            old mart
              @oldmart
              Got it, the first time I looked, the "QC" was black and I ignored it. Now it is blue, must be magic!
              #426093
              Phil Whitley
                @philwhitley94135
                Looks like the clamp let go, or loosened off, which would perhaps indicate that the cam on the clamping spindle is not going over centre enough to provide a tight fit. POS!! Glad to hear you are on the mend OuBallie!
                Phil.
                #426225
                mechman48
                  @mechman48
                  The material looks like a piece of crap ! You could have made a sleeve to fit the top slide bolt, that should be a tight fit in the top slide any way, secured with an anti rotation pin. Carbide inserts work best when speed is in high range & doc is 0.5 at least, if not more. Inserts need to be worked hard to get best results / finish.
                  George.
