power feed for miller
Home › Forums › Help and Assistance! (Offered or Wanted) › power feed for miller
  • #490724
    larry phelan 1
      @larryphelan1
      Good morning all,
      I am about to fit a power feed unit to my milling machine.
      The unit comes with a 110V plug unsuitable for our system, so needs to be replaced. The wires are black white green.
      Which is the live, white or black ?
      I suspect it is white, but just to be sure I decided to check
      Thanks for your help [always available ]indecision
      #33653
      larry phelan 1
        @larryphelan1
        #490727
        John Haine
          @johnhaine32865
          Umm… If it's a 110V plug, is a 110V motor? If so it might not be a good idea to just put a new plug on it, you would need a transformer too…
          #490730
          DC31k
            @dc31k
            If it is AC, it does not matter which you connect to live or neutral, but US wiring uses black for live.
            See:
            https://www.graphicproducts.com/articles/wire-color-coding/
            As John says, you need a transformer. A standard yellow building site one is cheap.
            #490732
            Bryan Cedar 1
              @bryancedar1
              You talk of two connections, do not forget the earth!
              #490771
              larry phelan 1
                @larryphelan1
                Yes John, it is a 110v motor, was ordered as such, so was fitted with a 110v moulded plug, just not the type we use., that,s why a new one has to be fitted. and I do have a transformer.
                Bryan, I did notice the earth connection, I,m not that brave. I dont take chances, even with 110 v !
                Thanks to all
                #490782
                  It’s a lazy and extravagant option, but adaptor leads are available to suit the yellow ‘site’ transformers:
                  A google search for :
                  iec 110v plug to american
                  should find one for around £25
                  That said, it’s only a five minute job to put an IEC plug on the lead.
                  MichaelG
                  #490805
                  Meunier
                    @meunier
                    I'm resisting the temptation, I really am trying, to enquire if that will need 'Arctic' cabling ? Oh, weak-willed again…….
                    DaveD
                    #490848
                    Paul Kemp
                      @paulkemp46892
                      I think it might need tropical cable at present or even sub sea cable depending on your location……… In fact an adaptor lead may be a very good suggestion, could have one for all seasons!
                      I'll get my coat,
                      Paul.
                      #490878
                      larry phelan 1
                        @larryphelan1
                        Maybe I should just go back to spinning the hand wheels ?frown
