Myford Super 7 Countershaft
Home Forums General Questions Myford Super 7 Countershaft
  • #152194
    Viv Watts
      @vivwatts
      Have had problems that even when the clutch on my Myford Super 7 is disengaged that a degree of 'drive' exists that will cause the chuck to rotate. Have adjusted the clutch plate that it is obviously disengaged so where is the friction coming from?
      With reference to section Q in the manual…Have removed the countershaft (102) with the twin pulley (112) and clutch plate (107) still attached. Need to seperate the clutch plate to examin it. Do I just screw in the screw that appears out of the drive plate (104) which I am guessing is the push rod (115). How easy is it to get back in? Seems very strong spring.
      #23300
      Viv Watts
        @vivwatts
        clutch friction
        #152207
        Ian S C
          @iansc
          Watts, I seem to remember a thread on the Myford and trouble with the clutch, but I don't know how it was headed, so I can't find it, maybe some one else will. Have heard that the spring is a bit lethal, takes off like a rocket when released. Ian S C
          #152208
          Nigel Bennett
            @nigelbennett69913
            It is a strong spring, but it's perfectly feasible to compress it again to re-assemble it. It's important that (as you say) you screw the pushrod IN and not out to dismantle it. I have dismantled mine a couple of times when I've changed the bearings in the clutch – it made a racket when disengaged.
            You need to have the push-rod and ball bearing assembled in place on the clutch operating shaft, press hard down on the driving plate and whilst it's pushed in, insert a smallish screwdriver (biggest you can get into the hole!), and rotate the push rod anti-clockwise to screw it into the drive plate. Make sure you engage at least a couple of threads before you stop pushing. A smear of grease on the threads beforehand may help.
            If you aren't strongish in the hands or suffer from arthritis or something, you may need to scheme out some kind of tool to compress the spring to re-assemble. I believe Myford of Nottingham had such a device, but I've no idea what it looks like. I guess it may have been some sort of device which fitted to the right hand end of the clutch assembly, presumably with the clutch operating arm removed.
            Get a 5/32" ball before you start, and then when the original one pings off and disappears, you can fit the spare.
            #152219
            Viv Watts
              @vivwatts
              Thanks, helps to search for the right words. Have it appart now, nothing untoward. Pully spins OK on shaft so a case of cleaning it up and re-assembly I guess.
