ML10 leadscrew clutch ID?
Home › Forums › Help and Assistance! (Offered or Wanted) › ML10 leadscrew clutch ID?
  • #550465
    Higgins1994
      @higgins1994
      hi, im in the midst of making a leadscrew clutch for my ML10and have come to drilling it through but unfortunatly i am in a sticky situation in terms of available drills haha. ive got it drilled to 15.90 but the nearest drill up from that that i have is 16.20 :/ has anyone here made one and can tell me if i will get away with that or will it be too loose on the leadscrew? the plain section of mine measures at 15.87 so assuming itll be a bit much
      cheers
      #33853
      Higgins1994
        @higgins1994
        #550702
        JohnF
          @johnf59703
          Hi, I think you need to revert to imperial sizes and my guess is the ML10 leadscrew is 5/8" 0.625 inches so best to azure a 5/8? reamer !
          PS where are yo located ? nothing on your profile !
          #550704
          not done it yet
            @notdoneityet
            Best plan is to try it – drills don’t always cut to their precise size It’s why reamers are preferred. 15.87mm is, indeed, exactly 5/8”. What sort of fit are you requiring? Likely already too big if needing a shrink fit.
            #550709
            Graham Meek
              @grahammeek88282
              From my days of owning a Myford ML10 this hole needs to be either bored or reamed 5/8" or 15.87mm, (15.90mm is top limit on a H7 hole). The finish left by a drill will hardly be good enough. There is also an Oilite bush present in the original Myford assembly for the threaded part of the leadscrew to rotate in. Remember the clutch continues to rotate when the leadscrew is disengaged, or stationary. Without the clutch the normal leadscrew rotates in two Oilite bushed pressed into the Bed. Thus the free end of the leadscrew needs some sort of bearing to support it, as the clutch body rotates. Steel on Mild steel is not a good mix without plenty of lubrication.
              Gray,
              #550866
              JOHN HORLER
                @johnhorler98360
                You will need to bore out the the housing to accept an oilite bush which myfords sell at a reasonable price,
                O/d is 3/4" ,bore 5/8", length 1-1/4", if the Bush is not fitted you will wear the leadscrew in no time.
                Hope this helps
                Regards John
                #550873
                duncan webster 1
                  @duncanwebster1
                  Oilite bushes have a slightly oversize bore as supplied, when you press them in to the correct size hole the bush bore finishes up at correct size. I'd make a plug gauge, measuring small holes accurately isn't easy.
                  #550875
                  JOHN HORLER
                    @johnhorler98360
                    Also don't forget to soak the oilite bearing in oil for 24hours before fitting
