Milling attachment for Warco wm290vf
Home › Forums › Workshop Tools and Tooling › Milling attachment for Warco wm290vf
  • #502967
    Brian Boyle 1
      @brianboyle1
      I am thinking of buying the milling head that fits on the back of the 290vf lathe.
      Has anybody got one. what are the disadvantages compared to the full wm16 mill?
      #19983
      Brian Boyle 1
        @brianboyle1
        Any opinions?
        #502970
          Small size table and lack of any fine feed along the X axis would be the two main drawbacks.
          #502981
          mgnbuk
            @mgnbuk
            Surely the normal lathe carriage feeds are available ?
            Remove the lathe chuck to avoid getting caught by it, select a suitable carriage feed and direction, engage the half nuts (or feed shaft if applicable) & run the lathe spindle to feed the carriage under the separately powered milling head. What would normally be considered the lathe Z axis would become the milling machine X axis.
            Still have the small table & lack of rigidity normally associated with a "proper" milling machine, though.
            Nigel B.
            #502985
              That's OK for power feed but unless you have the ability to stop exactly at the end of a non through cut then you are faces with how to move the carrage a small measured amount, carrage handwheel dial is only good for 0.020" divisions and does not have much feel for putting on a couple of thou cut or touching off on an edge. This is where a handle on the end of the leadscrew and a 1thou div dial helps like you can find on a Myford or My old Emco for example.
              Edited By JasonB on 23/10/2020 18:25:49
              #503001
              jimmy b
                @jimmyb
                I had a milling head on my SC4.
                The powerfeed was great, but simply not solid enough.
                I ended up selling it and putting the money towards a "proper" mill.
                Jim
                #503005
                Dave Halford
                  @davehalford22513
                  Correct me if I'm wrong here.
                  You save £300 and gain power feed, but-
                  Assuming you have to take the topslide off, you still get a tiny table with 2? short tee slots and you have 50mm more height/leverage before you can mount anything compared to the WM16.
                  I would expect it to chatter like crazy.
                  #503008
                  Cabinet Enforcer
                    @cabinetenforcer
                    You would need a DRO or the x-axis on the leadscrew will drive you potty. The table size is a masive compromise, and you can't realistically keep a vice mounted either.
                    I think the only reasons to buy one are either a very specific usage case which fits in the machines envelope, or having no space at all for a mill, as I think it is probably slightly better than using a vertical slide.
                    I seriously considerered getting a milling head for my 280 but I knew I would just get frustrated with the compromise and stuck out for a mill, it was the right decision.
                    #503016
                    Brian Boyle 1
                      @brianboyle1
                      Thanks for your thoughts guys. It looks like a proper mill is the way to go.
