Just for fun what’s this stuck in my tyre?
Home › Forums › The Tea Room › Just for fun what’s this stuck in my tyre?
  • #35601
    Ian Parkin
      @ianparkin39383
      #426261
      Ian Parkin
        @ianparkin39383
        I noticed this the other day stuck in my tyre driven about 50 miles on it…still held air over the bank holiday weekend
        what was revealed when the fitter removed the tyre ?
        Answer tommorow
        #426262
        David Davies 8
          @daviddavies8
          'Sparklet' CO2 cartridge? Blunt end of course!
          #426263
          Harry Wilkes
            @harrywilkes58467
            Mini grinding stone
            #426265
            Jeff Dayman
              @jeffdayman43397
              Looks like a Smith and Wesson .44 round. Is Clint Eastwood filming anywhere nearby?
              #426268
                Dinosaur tooth
                Phil P
                  @philp
                  Dunno what that is, but I had a bizzare puncture the other day that cost me a new tyre. It had 4" nail through it.
                  Now that may not sound all that strange, until I tell you the head was inside the tyre with the pointy bit on the outside. work that one out ?
                  Phil
                  #426275
                  ken king, King Design
                    @kenkingkingdesign
                    I would guess a golf tee.
                    #426277
                    vintage engineer
                      @vintageengineer
                      Ragbolt
                      #426278
                      I.M. OUTAHERE
                        @i-m-outahere
                        Cap screw or torx screw .
                        I once had a 6mm hex driver punch a hole a tyre – it was the long type you use in a drill/driver , the front tyre must have flicked it up when it ran over it and it landed at just tue right angle for it to puncture the back tyre . The other one was when i got a new car i took the entry to my drive a fraction wider than usual and as my water meter is buried in a cut out in the concrete driveway i ran over it and the shaft for the shut off valve went straight through a brand new tyre – i have now fabricated a cover for the meter !
                        #426279
                        Enough!
                          @enough
                          It's the tip of Clint Eastwood's finger which got sheared off when you drove into him in his wheelchair.
                          wink
                          #426282
                          Jeff Dayman
                            @jeffdayman43397
                            yessmiley
                            #426291
                            Brian G
                              @briang
                              This was annoying as with a Smart I had no spare tyre.
                              Spark Plug
                              #426293
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi, I recon a socket head bolt.
                                Regards Nick.
                                #426296
                                Mick B1
                                  @mickb1
                                  Posted by Neil Wyatt on 27/08/2019 22:40:39:
                                  Dinosaur tooth
                                  Triassic belemnite?
                                  #426303
                                  Ian Parkin
                                    @ianparkin39383
                                    David Davies was right straight away
                                    a NO cylinder
                                    #426305
                                    David Standing 1
                                      @davidstanding1
                                      Ah, 'hippy crack', N2O – you have no doubt parked in a quiet corner of a public car park, where the sniffers gather.
                                      I suspect some smart Alec deliberately wedged it under your tyre at an angle, so it did what it did and penetrated the tyre.
                                      #426310
                                      Ian Parkin
                                        @ianparkin39383
                                        David i did wonder if someone had done that
                                        but up here in the north the streets are littered with the little blighters
                                        #426311
                                        David Standing 1
                                          @davidstanding1
                                          Ian
                                          Plenty down here too!
                                          My guess it was wedged deliberately – their shape means it is unlikely one will flip up if driven over.
                                          Did you park in a multi storey car park prior to discovering it?
                                          #426330
                                          KWIL
                                            @kwil
                                            Pointy end just right for wedging in the tread gap, my guess deliberate.
                                            #426331
                                            David Davies 8
                                              @daviddavies8
                                              Ian
                                              Can I claim my prize? Someone said it is a Hardinge HLV-H lathe?
                                              Seriously, the gutters are littered with these cartridges around the Cardiff/Newport area. I see them lying there as I cycle in to work.
                                              Is your Comet back in one piece now?
                                              Cheers
                                              Carl
                                                @carl48656
                                                Looks like a bit of flint, maybe a Belemnite (bullet shape) fossil. Been to the beach ?
                                                #426357
                                                Samsaranda
                                                  @samsaranda
                                                  I am amazed at how many nails and screws litter our highways; when I was young screws and nails were relatively expensive and money was tight, you didn’t scatter them around like nowadays. People obviously have too much money if they can afford to waste materials as they do, nothing more annoying than getting a puncture that wrecks your tyre. I collected my car after a bodywork repair, not my fault guv, and when I got home realised that one tyre had a puncture, when the offending item was removed by a tyre fitter it turned out to be a bodywork fastening which had obviously got into the tyre at the repairers, so annoying , cost a new tyre not recoverable with vulcanised repair.
                                                  Dave W
                                                  #426368
                                                  David Standing 1
                                                    @davidstanding1
                                                    Posted by Carl on 28/08/2019 14:18:52:
                                                    You didn't read Ian's post at 09:23:55 then? wink
                                                    #426370
                                                    Nick Clarke 3
                                                      @nickclarke3
                                                      When I was very young a mate at primary school had an imported GI Joe toy and together we made an aqualung set for it using the identical cylinders, but that had held CO2 for a soda syphon.
                                                      Got an Action Man as soon as they were launched in this country (UK) but my mate reckoned his imported GI Joe was cooler.
