High-Precision Toaster required : Does such exist ?
Home › Forums › The Tea Room › High-Precision Toaster required : Does such exist ?
Viewing 13 posts - 26 through 38 (of 38 total)
  • #842102
      This looked quite promising … until I saw Sold Out
      MyMini Single Slice Toaster
        Robert Atkinson 2
          @robertatkinson2
          Fashion seems to be more important than function these days when it comes to kitchen appliances. For examples SMEG £150 for a basic toaster in black or green or £190 in white or emerald green. £40 more for a different colour…….
          Robert.
          #842112
          Grindstone Cowboy
            @grindstonecowboy
            There’s a few single slot toasters on Amazon but they all seem to have enough length to do two slices, so probably not what Michael needs – too big!
            Rob
            #842113
            David Ambrose
              @davidambrose86182
              Our Dualit is 1/2/3 slice by selector switch.
              #842158
              blowlamp
                @blowlamp
                There is a Single Slot Toaster at The Range.
                Martin.
                #842161
                  Thanks, Martin
                  Another one that’s “Out of Stock”
                  David Clarke 21
                    @davidclarke21
                    The “Sunbeam Radiant Control” toaster used to offer single slice operation.
                    It’s worth sparing 20 minutes on YouTube watching “The Antique Toaster that’s Better than Yours” by “Technology Connections”. Learn how a proper toaster works. Unfortunately no longer manufactured.
                    Direct link: https://www.youtube.com/watch?v=1OfxlSG6q5Y
                    #842202
                    noel shelley
                      @noelshelley55608
                      Michaels question is fine if the moisture content of the bread is known. But sadly this is where it all goes wrong. To get the precision that Michael wants requires for the bread to be of a known standard and consistent. Bread that is 2 or 3 days old will brown far quicker.
                      I’m sure if there was a market for such precision then machines would be available,to analyse the bread and then set the time for perfection. To go with this perfection one needs to be ready to collect the bread as it pops up, spread the butter and apply the jam then eat it whilst still warm. I find it’s better to under do it, then give the last few seconds, grab it and go.
                      Good luck in your quest Michael.     Noel.
                      #842214
                      peak4
                        @peak4
                        I’ve never been keen on review sites, or at least not keen on automatically believing their findings.
                        I do sometimes uses them as a bit of a specialised search engine.
                        https://www.oneclearwinner.co.uk/product/single-slice-toaster/t2/
                        First one Philips looks interesting, but I’ve never seen a glass sided toaster before (two slice though but arranged longways, which would suit me as I often buy non square bread.).
                        Bill
                        #842219
                        Grindstone Cowboy
                          @grindstonecowboy
                          They seem to have a generous interpretation of the term “single-slice-toaster” 🙂
                          Rob
                          #842220
                            On noel shelley Said:
                            Michaels question is fine if the moisture content of the bread is known. But sadly this is where it all goes wrong. […]
                            Did you watch the Sunbeam video that David Clarke linked ?
                            The patent seems to cover that little hurdle rather well.
                            .IMG_1496
                            #842229
                              The Daewoo glass fronted job looks interesting
                              But the quoted dimensions are somewhat variable !!
                              IMG_1497
                              Don’t believe everything you read 🙁
