High-Precision Toaster required : Does such exist ?
Home › Forums › The Tea Room › High-Precision Toaster required : Does such exist ?
Viewing 25 posts - 1 through 25 (of 38 total)
  • #841919
      I have at last found a commercial loaf which produces near-perfect Toast.
      Unfortunately, the ‘Goldilocks Zone’ is very narrow … probably 20 seconds between just-right and burnt !
      My wish is for a compact single-slice pop-up toaster with exceptional stability
      [ the existing two-slice job is wasteful, and disastrously inconsistent ]
      If anyone knows of such a device … please  tell.
      renardiere7
        @renardiere7
        The Holy Grill
        #841932
        John Haine
          @johnhaine32865
          There’s a way of knowing when
          Never try to guess
          Toast until it smokes, and then
          Twenty seconds less!
          – Piet Hein.
          The Sunbeam T series Radiant Control Toasters are reputedly the best ever made but were discontinued in 1997. Available on eBay.
          #841933
          John Haine
            @johnhaine32865
            On renardiere7 Said:
            The Holy Grill
            Excellent!
            #841935
            Speedy Builder5
              @speedybuilder5
              toaster or loaf ????
              #841943
              noel shelley
                @noelshelley55608
                First you need a moisture meter as this will dictate how long it is to heaven ! Noel.
                #841944
                  Thanks for the reference, John … it looks a work of simple genius:
                  Unfortunately, I need something that’s physically much smaller.
                  Bazyle
                    @bazyle
                    Amateurs!  Make toast the proper way by sticking it on a toasting fork in front of the fire and keep checking. It will vary with age of bread, room temperature, phase of moon etc.
                    What kind of butter do you use?
                    #841959
                      Bazyle
                      I have a lovely toasting-fork, that my Dad made about 70 years ago, but no fire … and a very small house.
                      Brittany Salted Butter from M&S
                      … and the bread, if you want to know, is their simple ‘toasting loaf’ with Sunflower Seeds and Spelt … Good wholesome stuff.
                      duncan webster 1
                        @duncanwebster1
                        When I was a student the rooms in hall of residence had a wall mounted electric fire. With a bit of ingenuity and a wire coat hanger making toast no longer required a trip down to the kitchen
                        #841967
                        Clive Foster
                          @clivefoster55965
                          I have one of the Sage “Smart Toast” 2 slice toasters.
                          It seems to be very repeatable in performance and the slider type control appears precise. Something of a poster child for excessive and inappropriate technology with its motorised insertion / extraction device, blinking LEDs progress indicator. and on the fly adjustment for a bit more toasting if the initial setting is too low. Presumably all to justify the price.
                          Her ladyship dumped it on me so its more than my life is worth to go back to my perfectly ordinary, cheap, toaster that has been perfectly satisfactory for the last decade.
                          I imagine the basic “A bit more” version is as effective at the toasting thing without the motor drive for around 2/3rd the price.
                          #841968
                          John Haine
                            @johnhaine32865
                            Why no consumer product company can design a toaster that just works properly in this day and she I just don’t know. Next they will launch Internet enabled toasters that connect to AI but reduce all your bread to slop.
                            #841969
                            Andy Stopford
                              @andystopford50521
                              Dualit:
                              2 Slice NewGen Classic Toaster
                              Two slice (or more) only, and, considering the price, you have to be very keen on toast. They do last for decades though.
                              #841979
                              Speedy Builder5
                                @speedybuilder5
                                It won’t be long before you could buy ready toasted bread or pre-digested bread for when we reach the care home!
                                #841981
                                cedric 1
                                  @cedric
                                  Propane torch and a pair of pliers. The model engineer’s toaster.
                                  #841983
                                    I  must particularly thank John Haine for quoting Piet Hein’s witty ‘grook’ … it states the problem beautifully.
                                    Here are a few more:
                                    https://www.nbi.dk/~petersen/Quotes/Grooks/grooks.html
                                    Andrew Crow
                                      @andrewcrow91475
                                      <p style=”text-align: left;”>Thanks Michael, we learn something new every day!</p>
                                      #841987
                                      Lee Rogers
                                        @leerogers95060
                                        Can’t help you with the single slice but my Dualit is the pro’s choice. A 30 second pre-heat results in very consistent results from 7am untill the last customer departs at 10.30. Expensive but all spare parts are available so once that you have one you can keep it going for ever. Things may fry and things may grill but the Dualit toaster goes on for ever.
                                        #841989
                                        noel shelley
                                          @noelshelley55608
                                          Lees point about a pre heat time is one of the problems, where the first slice may be under done and the second overdone as things warm up. How many people would want the complication or cost of such a machine – just for a slice of toast ? Industrial units do exist and cost £100s , I have one to repair that has a conveyor belt, bread in one side and toast comes out the other ! One problem was that people didn’t understand how it worked and would fiddle with the controls – I had to blank the controls off ! It would do 100s of slices every morning.  Noel.
                                          #842036
                                          Andrew Tinsley
                                            @andrewtinsley63637
                                            Not sure about a precision toaster. I can’t even find a single slice toaster. Yet everyone goes on about the need to conserve energy. So I have to soldier on with my two slice toaster and wasting energy!
                                            Andrew.
                                            #842046
                                              Well -said, Andrew
                                              My toast is always prepared one slice at a time !
                                              duncan webster 1
                                                @duncanwebster1
                                                I don’t think it takes a genius to make a 2 slice toaster into one slice. Unless the 2 pairs of elements are in series, just snip through one set
                                                #842051
                                                David Jupp
                                                  @davidjupp51506
                                                  A quick web search did find several single slice toasters.  Unsurprisingly, little information on ‘precision’ or repeatability.
                                                  #842083
                                                  Andrew Tinsley
                                                    @andrewtinsley63637
                                                    Hello Duncan,
                                                    Unfortunately all four of my toaster elements are in series. Otherwise I would have done as you suggested a long time ago.
                                                    David, I have done a web search several times for a single slice toaster, without any hits. Perhaps you could reveal your search term that gave you some results, I would be most grateful.
                                                    Andrew.
                                                    #842084
                                                    David Jupp
                                                      @davidjupp51506
                                                      ‘single slice toaster’ found a few, via google.
