Do hope ChrisJ that you find the book useful. If you do decide to make the grinding rest then have a look at these web pages, One modifications listed that is easy to make and definitely worth doing is to make the side arms (20) thinner. The web pages explain why and I see that Wolfie has done this.
You may also like to consider the modified off hand grinder to take white cup and saucer wheels. These are much better for grinding high speed steel, though of course far from essential.
You enquire Peter how good it is to work with.
Like all devices intended to be used for a wide range of sharpening tasks, setting up can need care, even the Quorn is renouned for being difficult for some tasks. Adding the magnetic bases, as shown at the second link above, does make one quicker to set up for the more complex tasks.
The following will show you what can be achieved using one.
Well done Wolfie, even if you never used it, and I am sure you will, you will have learnt a lot about using a milling machine, which is of course the main idea behind my "Complete Course" books, both for the milling machine and the lathe. Will be in contact soon.
Harold
