Flexible pressure bearing tubing
Home › Forums › General Questions › Flexible pressure bearing tubing
  • This topic has 11 replies, 9 voices, and was last updated 12 May 2014 at 20:56 by michael howarth 1.
  • #152251
    michael howarth 1
      @michaelhowarth1
      Can anyone tell me please whether or not it is possible to obtain flexible tubing that can withstand say 4 Bar pressure……something along the lines of braided flexible tap connectors but much finer….about 1/8" to 3/16". I would like to incorporate it into an air testing rig for small locos. I usually make do with 1/8" copper but it kinks easily and lacks flexibility when the loco has to be moved for adjustments etc. I have also tried rubber tubing but this suffers from ballooning or is otherwise too thick to give much flexibility.
      #23302
      michael howarth 1
        @michaelhowarth1
        #152253
        maurice bennie
          @mauricebennie99556
          Hi Mick Have you tried flexible car brake pipe used on most kit cars.
          Maurice.
          #152254
            I'm sure you could find something here:
            The clear vinyl tube is rated to 2.7 bar and goes down to 1/8 inch. I cant find braided-reinforced nylon tube less than 1/4 on that site, but I know In have seen it in very small sizes.
            Edited By Neil Wyatt on 12/05/2014 19:02:50
            #152255
              The plastic pnumatic tube will take 10bar plus and you can get easy to use push fit connectors, something like this unless you have a specific need for braided
              Edited By JasonB on 12/05/2014 19:01:53
              #152256
              Nick Hughes
                @nickhughes97026
                Hi Mick,
                Try Goodrich hoses as listed here:- **LINK**
                The 600-02 has a 2mm bore and a 5mm dia over the outer braid.
                This does tend to be expensive, but is probably the best and I've used Goodrich on my motorcycles for years.
                Nick.
                #152260
                WALLACE
                  @wallace
                  It’s a bugger to cut !
                  I’ve found a thin metal cutting disc in the angle grinder best – but will need flushing out to remove any cutting debris
                  W.
                  #152263
                  Bob Brown 1
                    @bobbrown1
                    Stainless steel braided Teflon hose (brake hose) is certainly an option, pressure is not a problem as it is good for +250 bar working pressure and should be OK for the temperatures just over 250 degree C. It is normally sized by dash number which is in 1/16" increments so -3 is 3/16. You should also be able to get snap connectors to make connecting things up very easy.
                    I find it reasonable to cut if you wrap the cut in tape and use a fine toothed saw, done it quite a few times in my motor sport days (rally cars)
                    Bob
                    Edited By Bob Brown 1 on 12/05/2014 19:22:45
                    #152271
                    nigel jones 5
                      @nigeljones5
                      wrap it tightly with insulation tape then cut through the tape – stops it flaring.
                      #152275
                      Oompa Lumpa
                        @oompalumpa34302
                        Posted by Bob Brown 1 on 12/05/2014 19:20:36:
                        Bob
                        Showing your age there Bob. I use a very good quality pair of sidecutters and as Fizzy suggests, wrap it in tape where you want to cut. Like Bob, I cut (what seemed like) miles of this stuff back in the day and I must say, using Goodrich or Earl's fittings I never had a failure.
                        graham.
                        #152279
                        Bob Brown 1
                          @bobbrown1
                          Wot's age got to do with it I did a race car for a mate back end of last year with the stuff!
                          It certainly does not come off very easily unless you want to remove the fitting, I've had a wheel smashed off the car and half the suspension wrecked but the caliper was still attached to the car by the hose
                          #152289
                          michael howarth 1
                            @michaelhowarth1
                            Brilliant gents, thanks very much for all that. Now off to do a bit of homework on what you have flagged up.
                            Mick
