Chuck back plate blank
Home › Forums › Beginners questions › Chuck back plate blank
  • #529143
    Me.
      @me1
      Anyone know where I can get a blank to make a backplate for my chuck, its to suit a L00 taper – Harrison 140.
      Seems to be a serious lack of L00 taper backplates.
      #10705
      Me.
        @me1
        #529149
        Oldiron
          @oldiron
          You probably need to ring round steel stock holders to see if they will cut a slug of BMS or Cast Iron of approximatly the right size for the back plate.
          regards
          #529150
            Rotagrip do them though not cheap
            #529158
            Lee Rogers
              @leerogers95060
              RDG do them but currently out of stock. Maybe a phonecall could shed some light on when available.
              #529163
              Me.
                @me1
                Posted by JasonB on 21/02/2021 16:13:14:
                Exactly what I want to make my own – …..
                I think the RDG ones are too small for the L00 taper – unless i'm looking at the wrong thing.
                #529168
                  Posted by Me. on 21/02/2021 15:49:44:
                  Me, can you confirm if you just want an unmachined casting or billet to make your own from scratch or a L00 backplate that is part machined eg thread and taper cut so you just need to cut the register. Until you cut the taper it does not become an L00 backplate and could be used for anything though you will need one with a larger boss than the usual Myford blank castings.
                  If it's just a billet, M-machine will cut you grey or SG Iron or you could get EN3 from someone like Steelcitygav on e-bay.
                  #529170
                  Dave Halford
                    @davehalford22513
                    Is this type thing no good (fordeight is Rotagrip)
                    #529192
                    Oldiron
                      @oldiron
                      Posted by Dave Halford on 21/02/2021 17:16:34:
                      That looks about right Dave. The L00 thread is i believe 3-3/4 x 6 so it looks as though there is enough meat there. It may be a little bit tight on the taper length though after cleaning up.
                      regards
                      #529286
                      Me.
                        @me1
                        I looked everywhere on the Ebay and came up with the nothing like that – that is exactly what I'm after.
                        I'll send them a message now. When you search there own web site it doesn't come up…. maybe it's me.
                        I'm not fussed if it was an unfinished project, a casting, billet or a finished article – I just wanted a L00 backplate.
                        #529368
                        old mart
                          @oldmart
                          It's not a backplate that I would like to tackle making. To get the taper right, I would get a dti set exactly on the centre line and run it against the nose taper of the spindle to set the compound. That is the most critical part, the threads are easier. Google for drawings of the L00 size. You will probably have to get a cut length of cast iron of slightly bigger than your chuck diameter and drill and tap it to hold it on a faceplate.
                          Every source of this size seems to be very expensive wherever they come from. I would check out the backplate listings on ebay every day, you could be lucky.
                          #529370
                          Me.
                            @me1
                            Hi – I'm pretty good at cutting tapers now having been "thrown" in at the deep end if you like with my Herbert Tapered Milling machine.
                            Setting up for the taper is the easy bit – the boredom of removing the metal is the hardest part to endure.
                            Theres plenty of "how too" videos on Youtube and believe me Ive watched them all…… Yawn…..
                            I am constantly on Ebay always looking – Plenty of L0 and L1 but the baby is proving harder to source.
