Article: A Simple Tailstock Depth Readout
Home › Forums › Model Engineer & Workshop › Article: A Simple Tailstock Depth Readout
  • #268905
    OldMetaller
      @oldmetaller
      I've just read the above article by Paul Tiney and enjoyed and was informed by it. Also, I had smiled three times and laughed out loud twice before I finished the first column!
      Can we have more from Mr Tiney, please? I don't normally get my laughs from MEW, but discovered I really enjoyed this mix of information and humour.
      John.
      #38378
      OldMetaller
        @oldmetaller
        MEW December 2016
        #268907
        Chris Evans 6
          @chrisevans6
          I have not seen the article but am part way through fitting a modified 6" digital caliper to mine. House guests arriving have stopped play.
          #268910
          Rod Ashton
            @rodashton53132
            It would be good if the "search engine" could find this article???????
            #268917
            Robbo
              @robbo
              Rod
              It's in issue 249 of MEW
              #268922
                I'm glad you enjoyed it John.
                The 'adjustable' nature of the idea is very handy too.
                Howard Lewis
                  @howardlewis46836
                  Like Chris evans, I tried drilling a cheap 6" Calliper for use as a tailstock readout. Took three sharpenings of a HSS drill for one hole. So bought a linear DRO, 'cos fitting that was so much easier. Right nuisance, tho' when changing the battery and the new one falls onto the floor!
                  #269021
                  Ian Parkin
                    @ianparkin39383
                    Re his article i read somewhere this week the difference between a rule and a ruler
                    Does any one else know that a rule starts at the end of the blade and a ruler may have a short start before the markings start
                    #269111
                    Ian S C
                      @iansc
                      I thought a ruler might possibly swing a blade in the form of a sword, I think a Royal nicked someone while doing that the other day.
                      Ian S C
