Any idea where to buy a square file 1/4″ x 1/4″??
Home › Forums › Workshop Tools and Tooling › Any idea where to buy a square file 1/4″ x 1/4″??
  • #19443
    Adam Harris
      @adamharris13683
      #426381
      Adam Harris
        @adamharris13683
        Can anyone steer me in the right direction to buy square files (straight, not tapered), in particular I would like to buy a 1/4" to help me finish off a keyway?
        #426424
        mechman48
          @mechman48
          Surely any well known DIY store will have them, maybe your 'local' hardware store too.
          George.
          #426427
            Don't think I have seen square files that size without a taper, probably better off with a Pillar file.
            Edited By JasonB on 29/08/2019 07:56:01
            #426444
            David George 1
              @davidgeorge1
              Hi Adam have a look at Vallorbe files they make any size and shape.
              David
              #426454
              roy entwistle
                @royentwistle24699
                I would use a three square file ( triangular ) rather than a square
                Roy
                #426464
                  Use a 1/4" thick rectangular file, you only need to put the edge in the slot. That's what I do.
                  Gary Wooding
                    @garywooding25363
                    +1 for a 3-square file – it makes sharper corners.
                    #426493
                    Ian P
                      @ianp
                      Posted by Gary Wooding on 29/08/2019 12:25:14:
                      That not really true all the time. I have square and rectangular hand files with sharper corners than all the triangular files that I have.
                      It only in theory that triangular are better for square holes.
                      Ian P
                      #426520
                      roy entwistle
                        @royentwistle24699
                        Ian P Not if you grind safe edges on them
                        Roy
                        #426522
                        Maurice Cox 1
                          @mauricecox1
                          It has been pointed out in the past, in M.E. , that square files are not in fact truely square. They were made like this to make it easier to file a triangular groove into a flat surface by using alternate corners; one corner would be cutting near the bottom of the groove, turn through ninety degrees and it cuts near the surface. I examined one of my files at the time, and the corners of that were definitely not right angles. I have no idea if this practice varied with size of the file, or if it is still done.
                          Maurice
                          #426526
                            As I say – use a flat file. You can get a cheap one for a few quid and grind it down to fit in a bore (I've done this before) or put a safe edge on it.
                            Jonathan Maes
                              @jonathanmaes16148
                              This might sound odd but if you have a mill with a quill on it you can grind a HSS blank to use as a broach. You can get them 1/4" square and then your corners would be dead perfect.
