Clarkson Tool and Cutter Grinder
Home › Forums › Manual machine tools › Clarkson Tool and Cutter Grinder
Viewing 25 posts - 1 through 25 (of 28 total)
  • #838338
    fishy-steve
      @fishy-steve
      Hi All,
      Does anybody know what the standard thread is that is used for the main cross slide.
      I’ve been given one and it appears the thread is the wrong hand! Turning the handle clockwise is traversing the table toward the user??
      Very odd!
      #838365
      renardiere7
        @renardiere7
        I’m pretty sure mine is a left hand thread, at least I hope it is as I recently obtained a LH tap to make up a new nut.  I’ll check after breakfast.
        #838368
        Tony Pratt 1
          @tonypratt1
          No idea of the thread but is this a real problem?
          Tony
          #838372
          John MC
            @johnmc39344
            My Clarkson T and C grinder was well worn, the previous owner replaced the standard leadscrew, 5/8″ x 14 LH, with an M16 x 2 RH screw.  Inconvenient, caused a few problems being the wrong hand.
            I replaced it with an M10 x 2 Trapezoidal (Acme) LH screw and nut bought from either Temu or Aliexpress, forgotten which, for a fiver, the correct hand, no more mistakes!
            The first photo shows the original LH screw (on the left) and the RH metric replacement.  The second photo shows the correct handed metric replacement, before fitting a graduated dial. Also a modified support for the lead screw, part of the attempt to make the machine foot print more compact. 17714871862041771487186190
            #838378
            Clive Foster
              @clivefoster55965
              Thanks for the details of Clarkson feeds screw size and the suggestion of an M10 replacement.
              Mine is floppy enough for replacement being desirable when round-tuit supply is sufficient.
              I guess the standard is 5/8 BSF but M10 x 2 means that some form of useful dial is possible. The pair are cheaper than a BSF tap too.
              #838393
              Julie Ann
                @julieann
                The cross slide feedscrew on my Clarkson T&C grinder, which I have no reason to believe is not original, is definitely left hand.
                Julie
                #838396
                peak4
                  @peak4
                  Just been out to check my spare Mk1 table, with 100 divisions on the handle dial.
                  0.619″ diameter 10tpi left hand.
                  My 55° thread gauge seems to fit the profile nicely.
                  Bill
                  #838400
                  fishy-steve
                    @fishy-steve
                    #838403
                    fishy-steve
                      @fishy-steve
                      #838406
                      fishy-steve
                        @fishy-steve
                        Double post
                        #838409
                        fishy-steve
                          @fishy-steve
                          #838410
                          Julie Ann
                            @julieann
                            I don’t have a dial on the handle on my Mk1 Clarkson and the thread is clearly finer than 10tpi.
                            Just checked and a 14tpi Whitworth gauge is a perfect fit.
                            Julie
                            #838412
                            fishy-steve
                              @fishy-steve
                              #838418
                              fishy-steve
                                @fishy-steve
                                #838423
                                John MC
                                  @johnmc39344
                                  #838425
                                  fishy-steve
                                    @fishy-steve
                                    #838466
                                    Clive Foster
                                      @clivefoster55965
                                      No dial on my Mk 1 and nor room for one either.
                                      Dunno how old mine is but Clarkson had a steady programme of improvements during the life of the Mk 1 so quite likely that later ones got them. No pictures showing a dial on a MK 1 in my collection of manuals and instructions. Although a manual featuring both Mk 1 and Mk 2 clearly shows a dial on the Mk 2.
                                      #838469
                                      fishy-steve
                                        @fishy-steve
                                        #838523
                                          There used to be a website with loads of pictures and info of Clarksons (apart from Lathes.co.uk) The site owner used to track every one that appeared on ebay. I don’t seem to have a link and it didn’t appear in the first couple of search pages. Anyone know what I’m talking about?
                                          Meanwhile this is useful https://bedroom-workshop.com/grinder-clarksondrawings/0grinder-clarksondrawings.html
                                          Actually it might have been the site above – I assumed it would have clarkson in the main  title when I searched. https://bedroom-workshop.com/
                                          #838538
                                          peak4
                                            @peak4
                                            #838708
                                            fishy-steve
                                              @fishy-steve
                                              Photos of my MK1 with dial as promised.
                                              20260220_190344
                                              #838710
                                              fishy-steve
                                                @fishy-steve
                                                20260220_190352
                                                #838712
                                                fishy-steve
                                                  @fishy-steve
                                                  20260220_190409
                                                  #838740
                                                  John MC
                                                    @johnmc39344
                                                    That’s not a Clarkson universal head is it?  Looks to be a better thought out device.
                                                    #838841
                                                    Andrew Kett
                                                      @andrewkett50664
                                                      Hello,
                                                      My late model March branded machine is 5/8 x 10TPI Left Hand.
                                                      Regards All,
                                                      Andy
