hi roger,
LINDA has stephensons gear indirect drive with rocker arms, and launch links and slide valves.
you are correct in assuming that the eccentric settings are shifted around by the amount of inclination of the gear to the cylinder centre line.
with launch links the angle of advance ought to be more than 6 degrees – though your reference to 6 degrees is the above inclination and not the angle of advance as commented by Neil.
my own version of LINDA is in 3.5"g and the gear was worked out by me using Don Ashton's excellent booklet many years ago.
cheers,
julian
