Number plate
Number plate
Home Forums General Questions Number plate
  • #24998
    VC
      @vc44480
      #277259
      VC
        @vc44480
        Hi all.
        Just a quick one
        What are motorcycle number plates made of ?
        Find them very easy to work with eg bend drill cut..
        But a real bugger to get the reflective bit off
        so would like to buy some before it becomes a number plate
        #277264
        David Standing 1
          @davidstanding1
          Some are acrylic, some are ABS.
          Edited By David Standing 1 on 12/01/2017 10:18:05
          #277265
          Gordon W
            @gordonw
            I've had the following – cardboard, plywood, aluminium, steel flat, steel pressed, cast alloy, plastic of varying types.
            #277271
            Ian P
              @ianp
              What properties are you seeking that motorcycle number plates have?
              If its some type of plastic its probably/certainly available in sheet form from lots of stockist.
              Ian P
              #277275
              Emgee
                @emgee
                VC, have you tried a hot air gun to aid removal of the reflective layer ?
                Emgee
                #277278
                Chris Evans 6
                  @chrisevans6
                  Have a look at direct plastics web site. You may see what you are looking for.
                  #277342
                  VC
                    @vc44480
                    Thanks for the reply's
                    Bit like looking up a word in a dictionary that you cant spell.
                    The plastic I'm looking for is not the stuff that you can buy in the DIY stores as this just cracks.
                    So still in the dark.
                    Thanks to all
                    #277343
                      VC
                      It might be worth contacting **LINK**
                      http://www.autoxtra.net/components.html
                      They offer two plastic versions:
                      1. Acrylic and
                      2. something better !!
                      I presume you want type 2
                      david homer
                        @davidhomer12226
                        Look for Makralon polycarbonate sheet, it was machine guards are made of, impact resistant and does not crack like acrylic.
                        David
                        #277346
                        Nigel Bennett
                          @nigelbennett69913
                          If you use polycarbonate, DO NOT use Loctite on any screws that you use to secure it. It attacks the polycarbonate.
                          #277355
                            Posted by Nigel Bennett on 12/01/2017 17:18:17:
                            It wicks into any cracks and can cause splits. Other solvents can do this as well.
                            Polycarbonate is available at B&Q but only as large sheets of thin 2mm material.
                            Available in allsorts of sizes online.
