Myford super 7 mk1
Myford super 7 mk1
Home › Forums › Workshop Tools and Tooling › Myford super 7 mk1
  • #18478
    Anders B
      @andersb45152
      #293160
      Anders B
        @andersb45152
        Hi,
        I have mk1, and I like to know if it is possible to replace the mk1 clutch with a mk 2 clutch?
        And, I like to know if it is possible to mount a quick change gearbox ?
        Br
        Anders
        #293171
        Sandgrounder
          @sandgrounder
          I've replaced the clutch on my Mk1 with a Mk2, I bought a complete clutch assembly off eBay and it mounted straight on to the existing 'Pivot Shaft', I had to remove and refit the 'Twin Vee Pulley' so the shaft could go through the 'Motor Drive Belt Guard Backplate', that was the hardest part, the only actual modification required was to the 'Headstock Belt Guard', this had to have the cut outs which allow the clutch to pivot increased, this was done easily with hacksaw and file. I was told a Mk2 'Headstock Belt Guard' won't fit a Mk1.
          Anders B
            @andersb45152
            Ok, Thanks for the description, it should be easy enough to do. smiley
            #293182
            Robbo
              @robbo
              Anders,
              My Mk1 has been fitted with a gearbox, just the usual procedure re leadscrew etc.
              Also replaced the old clutch with a Mk2, straightforward job if the complete assembly is used, the parts of the Mk1 and Mk2 are not interchangeable.
              As John says, the belt guard needs modification, I chose to "lift" mine by using blocks under the mountings, and reversing the spring clips, This just avoids extending the cutouts at the side. A hole was needed in the drive belt cover to accommodate the end of the clutch shaft.
              Edited By Robbo on 13/04/2017 08:59:52
              #293191
              Sandgrounder
                @sandgrounder
                Posted by Robbo on 13/04/2017 08:59:13:
                Sorry, I'd forgotten about that mod, I made the hole and fitted a cover and spacer over it.
                Edited By Sandgrounder on 13/04/2017 10:27:58
                #293227
                Robbo
                  @robbo
                  And I didn't mention that raising the cover mountings means a longer locking plunger (which holds the cover open) needs to be made.
                  But these are incidentals which crop up along the way!
                  What was most pleasing (as well as having a clutch that worked smoothly and without rattling) was to find that by reversing the closing clips on the sides of the cover they would still work with the higher cover mountings, with the minimum of work.
                  #293352
                  Anders B
                    @andersb45152
                    Hey guys. Thanks for all the great advice, I think I will look around for a mk2 assembly yes
                    Br
                    Anders
