Would this improve the quality of signal to a CNC machine?
Home › Forums › The Tea Room › Would this improve the quality of signal to a CNC machine?
Viewing 25 posts - 1 through 25 (of 44 total)
  • #530408
    Ian P
      @ianp
      I've put this in the Tea Room as its mostly for discussing the pro's and conn's of cheap versus expensive cables between PC's and driven equipment.
      Is seems that (apparently) transferring digital audio signals is best achieved by using only the highest quality cables. I have always understood that digital was digital and thought that as long as a USB cable transfers the 0's and 1's to the far end it would have no effect on the sound quality. Since the cables in the links below improve the sound quality, would these cable make CNC machined parts even more accurate?
      devil
      Edited By Ian P on 26/02/2021 20:08:11
      #36302
      Ian P
        @ianp
        (If it used USB for data transfer)
        #530413
        HOWARDT
          @howardt
          Cheap compared to some Kimber hi-fi cables. Not convinced that beyond switching away from bell wire or equivalent makes much difference, but then I only listen to LP,s.
          #530414
          Andrew Tinsley
            @andrewtinsley63637
            Ah! That reminds me that gold plated pins on a 13 amp socket, definitely improve the audio from good analogue audio amplifiers!
            Andrew.
            Edited By Andrew Tinsley on 26/02/2021 20:16:09
            #530415
            Tom Sheppard
              @tomsheppard60052
              Sheer twaddle. Electrons aren't fussy.
              #530417
              James Hall 3
                @jameshall3
                I think that someone has (apparently) been pulling your plonker.
                IFF the bits are getting transmitted and received correctly the quality of the cable will make absolutely no difference.
                Unless you are sending signals over too long a distance or in a high noise environment the chances are that a cheap cable should be fine (subject to correct manufacture).
                Be wary of advice from hobby mags on these matters – particularly when talking about hi-fi – kit reviewers and bloggers have to maintain interest and hence sales; one of the ways they do this is by cooking up fashions for one expensive tweak or another. Remember when sounds weren't worth listening to unless your speakers were hooked up with cable capable of serving the National Grid – but with five million cores!
                #530419
                Emgee
                  @emgee
                  Screened cables usually provide better interference rejection.
                  Emgee
                  #530427
                  Anonymous
                    Posted by Tom Sheppard on 26/02/2021 20:20:08:
                    Hmmm, not an electronics engineer I presume? Electrons most definitely are fussy, and can be extremely annoying when they don't flow where you expect. smile o
                    The USB signal (1.x and 2.0) is differential, transmitted over a twisted pair with a nominal impedance of 90 ohms. If the impedance is wrong and/or the lines are not terminated properly then reflections and overshoots will occur, ultimately leading to loss of signal integrity.
                    A digital signal is really an analogue signal. In some ways digital is more challenging than analogue as the fast edges imply a larger bandwidth than might be suggested by the data rate. If the transmission channel is not linear, ie, non-dispersive, then distortion of the signal will result leading to problems in decoding the signal. There's a vast literature available on the transmission and decoding of digital signals, with some pretty hairy mathematics.
                    Having said the above a quality USB cable will not be expensive. The cables linked to in the OP are nothing to do with technical ability; they're intended to separate fools and their money.
                    #530432
                    Ian Parkin
                      @ianparkin39383
                      I see that in Ians links to the cables they can add on a cable of  three thousand pounds a contract enhancer for only an extra £3.20
                      must be some special snake oil…
                      I’d love to know how many cables they can sell at those prices
                      Edited By Ian Parkin on 26/02/2021 21:53:18
                      #530433
                      James Hall 3
                        @jameshall3
                        A digital signal is most definitely NOT an analogue signal. Over copper it is transmitted by way of an underlying analogue signal, but that is a different matter and the two signals are quite discreet.
                        #530435
                        Ian Parkin
                          @ianparkin39383
                          And look at the cost of mains cables a 10m iec set for only £13,800
                          where do they think the electricity comes from to supply the mains socket
                          makes a new myford look good value
                          Edited By Ian Parkin on 26/02/2021 21:57:49
                          #530436
                            USB doesn't provide any error correction itself so maybe a bad connection due to an unshielded cable in an electrically noisy environment or wobbly plugs could corrupt the digital stream.
                            I don't know what hi fi systems do, but computers send and receive data in check-summed blocks and usually ask for repeats until they get clean data. Broadcast digital tv and radio can't ask for a repeat so they just drop the offending block causing audio to go silent or the screen to pixelate. The quality of received segments is perfect, but they are interspersed by obvious glitches. Unlike an analogue system It either works or it doesn't: there is no general low-level loss of quality, just good and bad blocks.
                            Maybe hifi systems use usb cables as ordinary audio connectors and aren't digital at all. A convenient bodge, but prone to analogue defects, that might be reduced by a decent cable.
                            What's needed is a good dose of double-blind testing. For some strange reason it's never done…
                            Anonymous
                              Posted by James Hall 3 on 26/02/2021 21:52:37:
                              ……….and the two signals are quite discreet.
                              That's a new one on me. I've never seen a signal, analogue or digital, that aimed to avoid social embarrassment. smile
                              It's convenient, and may be logical, to think of a digital signal as being one of a small set of values. But in reality, however it exists, the actual signal is analogue. Would a FSK signal be analogue or digital?
                              #530439
                              Martin Kyte
                                @martinkyte99762
                                I have to agree with Andrew in this one. The signal is analog. The signal is interpreted as digital by the receiver circuit defined by it's threshold levels. Digital coding, analog transmission. You could transmit digitally by sending single electrons with the data coded in spin up or spin down but the cost of your system would make the USB cables above seem cheap.
                                regards Martin
                                #530458
                                Martin Connelly
                                  @martinconnelly55370
                                  My ears are well past their best before date. I doubt any amount of money thrown at a sound system will ever make it sound as good as when my ears were still in the first flush of youth.
                                  Martin C
                                  #530463
                                  Hopper
                                    @hopper
                                    Yes, I just spent $1,000 on a new sound system. Then realised the sound is only going to be as good as my two hearing aids!
                                    Oh well, at least it's loud enough that I can't hear my neighbour banging on my door, or his bloody dog barking.
                                    #530468
                                    Ady1
                                      @ady1
                                      Plus our hearing degrades quickly as we age, particularly for the higher ranges
                                      Those fabulous ABBA sounds of our youth can never be as good in our old age no matter what we do
                                      Chap on my dog walk showed me with a phone app, neither of us could hear a thing in the higher ranges, even though those sounds were within the audible range for a human
                                      #530476
                                      Hopper
                                        @hopper
                                        Yep that's me. Can't hear the beeper on the microwave any more or the "lights on" alarm beeper when getting out of the car. Shoulda worn earplugs in all those power stations I guess. Let alone Harleys with straight pipes and Nortons with megaphone mufflers. But that would have been uncool.
                                        #530480
                                        Dave Halford
                                          @davehalford22513
                                          You certainly get errors at 2mbit and above from a bad connection so decent connectors are worth paying for and it also helps that the impedance of the cable is what it says it is. Good screening will help stop the VFD noise getting on the cable.
                                          Will it make a difference CNC, no ideasmiley
                                          #530485
                                          James Hall 3
                                            @jameshall3
                                            Martin Kyte: you may well agree with Andrew Johnston on this one but you would, with respect, both still bee wrong.
                                            This really is DigComms 101 – kids' stuff. To say that a digital signal is really an analogue one because it is carried over an analogue channel is as ridiculous as saying that an analogue signal is really a piece of wire because the piece of wire carries the electrons. I've tried to think up an illustrative analogy with the difference between the meaning of word and a dumb spell-checker for you further amusement – but it proved to be too contrived.
                                            #530491
                                            Anthony Kendall
                                              @anthonykendall53479
                                              Being a simple person, I like to look at it like this.
                                              Digital signals are decodeable providing noise added does not approach the amplitude of the digital signal such that it is not possible to reliably distinguish between a nought and a one.
                                              The length of the cable will have an affect – as distance increases, the amplitude of the wanted signal decreases and the noise gets proportionally greater, depending on the environment.
                                              Thus, any cable should be low loss and screened.
                                              To answer the OP – unless you are going to send signals to your mate's house down the road, the normally available screened cables will suffice. This should cost no more than 2 quid per metre. It might even get you to your mate's house as well!
                                              #530495
                                              Emgee
                                                @emgee
                                                Posted by James Hall 3 on 27/02/2021 10:13:25:
                                                Bit of a sting there James however it's read.
                                                Emgee
                                                #530500
                                                Martin Kyte
                                                  @martinkyte99762
                                                  Any time varying current is analog. I suppose you would agree that a sine wave is an analog signal. Well a pulse train is a series of sine waves of different frequencies. Do the Fourier transform. For USB the data is encoded and decoded as digital on the analog carrier as I said which is what makes it a digital communications channel but the connection is analog. It is splitting hairs but that's the way it is.
                                                  regards Martin
                                                  #530510
                                                  Tom Sheppard
                                                    @tomsheppard60052
                                                    A digital signal is an analogue signal with only two or three levels. That is why it is called a digital signal. (Yes, if zero is a level, and it is, then digital signals can have three levels, but they are still digital signals.)
                                                    #530551
                                                    Anonymous
                                                      I must have skipped that class. You're not the first new member to wade in guns blazing and telling people that they're idiots and I don't suppose you'll be the last. Generally it reflects badly on the new poster and while some quieten down many disappear without trace.
                                                      As a doctor I'd advise you to visit your GP, as breathing cutting oil fumes seems to have affected some cognitive abilities.
