Richard is a good bloke – lives near here – and his books are invaluable.
Most wood turning is pretty freeform just because the wood itself is unreliable. If you want a cylinder to be concentric, then use of a skew or gouge may cause issues as the bevel runs on the previously cut surface – effectively the depth of cut is relative to the surface rather than relative to the lathe!!
While a scraper will not give the same finish, it is much better at referencing depth of cut from the tool rest.
There are many safety consious turners who will not go near an old file. The critical point is that if the distance between rest and work is too large (>10mm) as it often needs to be for curves, there is real risk of a catch and breaking the file. followed by ramdomly fired bits of iron.
You can easily make a very good scraper from a piece of HSS 25*5(or6)*200. grind a30deg bevel across the one end (you may wish to angle this at about 15deg to create small undercut areas but I havent needed that).
Grind a tang of about 75mm at the other end an fix a handle. handle needs to be the length of your forearm – some like them longer.
In use, the best finish from a scraper is obtained if you push up a burr after sharpening. In HSS this will require a very firm push with a piece of round HSS. the wire edge from sharpening is not really strongenoug to last.
I have two made this way, the other has a gentle curve and is OK for hogging, bu not for getting a parallel finish. Some people prefer high-carbon tool steels rather then HSS as the burr is easier to achieve and there is a view that these have better wear resistance.
