Boiler problem
Boiler problem
  • #855855
    Zan
      @zan
      I have a small foundation ring leak.  I am told this can be repaired  with Radweld
      Does anybody have experience  of this and are there any problems with using it to seal the leak
      #855885
      Nigel Graham 2
        @nigelgraham2
        Really, you’d need give a lot more information than that for anyone to be able to give a very useful reply:
        The type of boiler,
        Working pressure (possibly considerably higher pressure hence also temperature than in a car radiator, so ‘Radweld’ or similar would not be suitable),
        Shell material and method of construction,
        General condition of the boiler.
        If you can attach suitable photographs, that could be helpful too.
        #855919
        martin haysom
          @martinhaysom48469
          Radweld wont repair it, it will only bodge it .
          #855926
          Zan
            @zan
              <li style=”text-align: left;”>I tend to agree
            Boiler dia 7″ vertical for a lorry copper.
            Was ok at steam test 3 months ago
            The rate is  about 2 drips in 3 mins. However the pressure yesterday was up and down like a yoyo
            One guy I spoke to had contact with radweld labs who said it would be OK.   It was for two boilers years between  them.
            Can’t upload the photo at the moment it was  stuck on 58% for 10 mins.  I’ll do it later
            I’m just trying  to avoid the massive task of taking the boiler out of the engine and I value more help and advice
            #855950
            noel shelley
              @noelshelley55608
              As Nigel has said , is this the beginning of a more serious problem ? On new boilers in full size it was not uncommon for numerous things to be used to seal small leaks, but that was a new and sound steel boiler. Since it has just had a boiler test I would seek the advice of your boiler inspector.
              The dog turd type of rad sealer was often Fullers earth, unlikely to be affected by the temperature, the pressure is another matter. Since it’s copper one cannot rely on corrosion !
              Since you say foundation ring, failure could turn the boiler into an impressive rocket ?  Good luck.  Noel.
              #855951
              duncan webster 1
                @duncanwebster1
                Another old school sealant was horse muck, not appropriate here. Have you tried applying a flat ended punch to the outside around the area of the leak. If it has withstood 2* hydraulic there is little chance of catastrophic failure. as others have said talk to boiler inspector first
                #855993
                Nigel Graham 2
                  @nigelgraham2
                  One possible cause of a small leak is a patch of joint that did not fully solder, leaving hardened flux to “seal” it. In time the flux dissolves to leave a leak path.
                  #856028
                  Zan
                    @zan
                    Nigel agreed, the boiler has been out for a small hole in the foundation ring last year I thought it had been sorted with comsol. I’m beginning to think about a new boiler.
                    Problems started after descaling with “Kilrock”I kettle  solution but think it was too strong a mix
                    Duncan,  the punch method would only be possible after removal of the boiler, then putting it back for a steam test after the hydraulic. A really big task.
