Why does everyone disagree with you
Home › Forums › General Questions › Why does everyone disagree with you
Viewing 25 posts - 101 through 125 (of 140 total)
  • #449576
      Posted by Bill Phinn on 29/01/2020 02:29:16:
      Yes, the change to "head of a pin" misses the point, as you say.
      To continue in the same spirit as those medieval theologians who engaged in lengthy and somewhat pointless disputes, I have to say I'm not sure I can agree with Peter Harrison's claims when he says: …
      although the transition to "head of a pin" from "needles point" is a pity, there is nothing wrong with translating Latin acus as pin, since acus can mean both pin and needle.
      Many thanks for the thoughtful reply, Bill
      … We best not ‘work it to death’ or some on the forum might protest. angel
      The relevant thing here was the move from the [Euclidean] point, which has zero area, to the mechanic’s head of a pin [which has small but finite area]. The ambiguity between needle and pin is, I suggest, of no consequence in the theological discussion.
      The common jibe falls on deaf ears, because it is ill-founded
      blowlamp
        @blowlamp
        I've solved this problem over a cup of tea. tea
        If the point of a pin is of zero area then it ceases to exist as an object in itself. Therefore, no number of angels could dance upon it, even if these angels themselves occupied zero area – in which case they'd also cease to exist. enlightened
        On the other hand, any number of angels could dance upon the head of a pin, given the right relative scale between the two.
        Edited By blowlamp on 29/01/2020 11:21:36
        #449602
        Georgineer
          @georgineer
          To introduce an engineering slant to the needle's point discussion, when I was a new apprentice three of us were given a project to design and build a balancing machine for car wheels. We decided to go for a cone arrangement balanced on a point, with a spirit bubble to indicate level.
          Our instructor told us that it couldn't possibly work because the point, having zero area, would be subject to infinite force which would destroy it. We, being spotty yoofs but lately out of school, couldn't counter his arguments but built it anyway, and it worked as well as any first year apprentice project does.
          By the way, Steve, if you're still reading this thread which you started, although it has wandered from your original subject, it is a model of respectful discussion with a modicum of erudite teasing. In my experience this is something this forum does extremely well.
          George B.
          #449603
          Howard Lewis
            @howardlewis46836
            Well, at least I stirred that Hornet's nest without getting stung too badly! (This time! )
            #449610
            Martin Kyte
              @martinkyte99762
              OK, I'll bite. Some little while ago there was a greek who postulated that matter was not infinitely subdivisible, which at some later date became adopted as one of the founding tenets of physics, namely that all matter is composed of atoms. Needles are thus a pile of atoms (or sometimes molecules) and so the sharpest point on any given pin has the limiting dimensions of the atomic radius of it's particular atomic constituants. The point of the pin thus has a non zero area. The minimum area pin should be composed of carbon (diamond) with an atomic radius of 60 picometers or 0.6 angstroms if you prefer. One could conceive of a pin composed of solid hydrogen which would bring the radius down to 25pm or 0.25 angstroms.
              Regarding the angels there are two possibilities. (Ignoring the 3rd case of the non-existance of angels making asking the original question void)
              1. Angels are non-matterial entities and are not constrained by atomic dimensions in which case no comment can be offered.
              2. Angels are material beings. In which case the smallest form they can take would be a single atom which would not sensibly define them as angels (unless all atoms are angels) and would pose the question what the heck de we mean by dancing. In which case we come up with the answer of one or none.
              As someone once said ' ask a silly question' and sometime you get a reasonable answer which is of no help whatsoever.
              ;0)
              Martin
              #449612
              Robert Atkinson 2
                @robertatkinson2
                Talking of pins, in a previous employment we made (I say made but two specialist subcontractors were used) pins that had flattened points less than 1um ) 0.001mm in diameter and split down the center like a quill pen. The run-out was <2 um (from memory) and they were supplied as sets with the lengths matched to much less than 1um. The material was tungsten carbide but even so just touching the point was enough to damage them. They were very expensive. Shown as item 21 in this patent that gives an idea of the application.
                The pins weren't patented, to do that would have revealed how we made them.
                Robert G8RPI
                #449614
                Mick B1
                  @mickb1
                  I'm not sure. If an atom has a radius then it's presumably that of the outermost electron shell. If the pointy thing's point comes down to a single atom, then the point must be the point furthest from the point (or head) at t'other end, at the surface of the electron shell that's also furthest from point at t'other end, ie. back to dimensionless point upon a sphere.
                  Or do needles have flats on the end?
                  No wonder religion's so contentious.
                  Robert, how many could sit on your flatted carbide points? Would there be room for more if the points weren't divided, or would some of them fall down the crevasse?
                  Edited By Mick B1 on 29/01/2020 12:54:10
                  #449617
                  Steviegtr
                    @steviegtr
                    Posted by Georgineer on 29/01/2020 11:24:34:
                    George B.
                    Well I am following it , albeit dumfounded.
                    Steve.
                    #449630
                    blowlamp
                      @blowlamp
                      Posted by Steviegtr on 29/01/2020 13:34:11:
                      George B.
                      Steve.
                      This is how discoveries are made! angel
                      Edited By blowlamp on 29/01/2020 14:36:43
                      #449639
                      Howard Lewis
                        @howardlewis46836
                        Possibly the thread is this long and erudite because some of us have too much time on our hands, certainly me.
                        And that should generate a disagreement!
                        #449646
                        Peter G. Shaw
                          @peterg-shaw75338
                          Well, (Baby), it's cold outside; I keep getting bored with genealogical research (I find myself going round in circles); most of the goggle box is utter rubbish, indeed I can't even be bothered looking; so what else am I to do? Mind you, my standard of erudition is pretty poor.
                          Peter G. Shaw,
                          (who failed English Language, English Literature and French, and dropped aLtin after two years. Which allows me to claim that I have failed anything and everything to do with languages that I have ever attempted.)
                          #449654
                            Posted by Martin Kyte on 29/01/2020 12:32:24:
                            Great post, Martin yes
                            The accepted wisdom is that Angels are non-corporeal, and therefore do not inhabit a dimensional space. [*]
                            As such: The original question that worried Aquinas is not valid for any ‘real world’ interpretation of a point … but only for the Euclidean version.
                            It should now be obvious why the ‘needle’s/needless point’ pun was so clever, and why reference to the head of a pin is crass.
                            [*] Bazyle’s cuppa got him very near.
                            Edit: It’s getting colder … so here is Euclid’s succinct definition of a point:
                            https://mathcs.clarku.edu/~djoyce/java/elements/bookI/defI1.html
                            Edited By Michael Gilligan on 29/01/2020 16:20:03
                            #449662
                            Bill Phinn
                              @billphinn90025
                              Posted by Michael Gilligan on 29/01/2020 08:49:54:
                              Exactly right.. And whether the "point" individual medieval theologians had in mind when they wrangled over this question [assuming we can accept they did] was the real-world point or the geometrical one makes a huge difference to the parameters of the question they were trying fruitlessly to solve.
                              Posted by Michael Gilligan on 29/01/2020 16:13:40:
                              σημεῖόν ἐστιν, οὗ μέρος οὐθέν – literally [the bit outside the brackets]: "a point is [a thing] of which [there is] part no."
                              #449663
                              Grindstone Cowboy
                                @grindstonecowboy
                                What those medieval theologians needed was a workshop each, then *they* could have had the debates about HSS and carbide, Myford and Boxford, etc and saved us all the bother
                                #449664
                                Mick B1
                                  @mickb1
                                  Well, 'tain't really Euclid's definition, is it, but David E. Joyce's interpretation of various others' interpretation of it?
                                  Looks to me unfairly insulting to Euclid – 'primitive' definitions and all that. You gotta remember he wasn't standing on shoulders of giants like wot we are today – Euclid's amongst them. He had to work this stuff out from pretty much zilch, and no angels to help him either – they weren't invented till later; and of the gods and goddesses only Athene knew anything about anything, and she was too busy intervening in other affairs most of the time.
                                  #449667
                                    Posted by Mick B1 on 29/01/2020 17:04:59:
                                    Looks to me unfairly insulting to Euclid – 'primitive' definitions and all that. […]
                                    Please see Bill Phinn’s post
                                    I have no Greek, so must rely upon translations supplied by others.
                                    … but the ones I have seen are pretty consistent.
                                    I would be happy to see your offering.
                                    P.S. … Try copying Bill’s Greek text into a Google search box
                                    Edited By Michael Gilligan on 29/01/2020 17:22:25
                                    #449670
                                      Euclid's genius was his conception of a useful entity# that doesn't exist! He invented the point as 'that which has no part' – meaning something with a location, but no width, breadth or height. Particularly clever because location is also difficult to imagine, because it can only be defined in terms of a reference point. It's conceptually recursive, ie the whole notion disappears up it's own fundament!
                                      Like points, infinity, and the square root of -1, zero doesn't exist in the real world either! It should be complete nonsense. Amazing that all these ideas are so incredibly useful. Unlike angels…
                                      # Entity is a posh word. It means thingy.
                                      #449678
                                      blowlamp
                                        @blowlamp
                                        Now that all points are covered, I'm more concerned I've just remembered that angels are men.
                                        So whereas I was considering the idea of Legs & Co frolicking aboot on a pin, I now see an all male dance troupe such as the Chippendales – only with wings.
                                        #449698
                                        Meunier
                                          @meunier
                                          Posted by Michael Gilligan on 29/01/2020 17:17:53:
                                          .snip/
                                          Edited By Michael Gilligan on 29/01/2020 17:22:25 /snip
                                          Thank you for that suggestion MichaelG, a fruitful result.
                                          DaveD
                                          #449701
                                          old mart
                                            @oldmart
                                            Similar rubbish like" if a tree falls in the forest and nobody hears it, doe's it make any sound?, or something like that. Argument for arguments sake.
                                            People often disagree with me when I'm wrong, and sometimes when I'm right.
                                            #449714
                                            Georgineer
                                              @georgineer
                                              Posted by Robert Atkinson 2 on 29/01/2020 12:42:23:
                                              Robert G8RPI
                                              I reckon you did the turning on a Myford. The split down the centre was done with a junior hacksaw and – here's the secret – you used Trefolex on the blade.
                                              George B.
                                              #449715
                                              Steviegtr
                                                @steviegtr
                                                oy there ain't nothing wrong with trefolux or a junior hackenshmit. Hmm Myford.
                                                #449716
                                                old mart
                                                  @oldmart
                                                  One perennial topic that is guaranteed to cause a wailing and gnashing of teeth is whether a three jaw chuck needs a tight or loose register with it's backplate.
                                                  #449717
                                                  Steviegtr
                                                    @steviegtr
                                                    Posted by old mart on 29/01/2020 21:19:06:
                                                    Does it. ??? I have a backplate that came with the machine but the register is undersize.
                                                    Steve.
                                                    #449721
                                                    old mart
                                                      @oldmart
                                                      Steve, all of the three jaw chucks for the museum's lathe and the er25 collet plate have their registers intentionally reduced to allow fine adjustment of their concentricity if required. Some people get so incensed about my butchery that I'm in danger of being excommunicated, or having a fatwa against me.
