What to blacken steel with
Home › Forums › General Questions › What to blacken steel with
  • #447273
    Steviegtr
      @steviegtr
      Anyone know how to blacken steel or any other metal. Is it a dye or a process with chemicals. I use liver of sulphur for Zinc. But not sure about other metal's. By blacken I mean like gunmetal etc.
      Steve.
      #27081
      Steviegtr
        @steviegtr
        Colouring steel
        #447275
        Thor 🇳🇴
          @thor
          Hi Steve,
          You can buy so called cold blacking solutions for steel, a friend of mine has tried and it works. I just heat the mild steel parts to about 270 to 300 deg. C and apply linseed oil, the treatment will to some degree protect against corrosion. Others use motor oil. The treatment is best done outdoors.
          Thor
          #447281
          Baz
            @baz89810
            I have also used the cold blacking kits for steel and am quite impressed with them, the only one that I cannot get to work is the brass blacking kit.
            #447284
            Danny M2Z
              @dannym2z
              Posted by Steviegtr on 18/01/2020 02:09:29:
              Steve.
              Just google "cold blue for barrels" then pick whatever you can legally purchase.
              One tip, Cleanliness and de-greasing is mandatory.
              * Danny M *
              #447290
              Mick B1
                @mickb1
                Gun-bluing paste G96 works for me on a warm and well-degreased surface. It's generally well-regarded as a quick and relatively simple home bluing or blacking solution. Last for decades at least. There's a Phillips lookalike that works pretty much the same. See the 24-pdr cannon in my album for evidence.
                Edited By Mick B1 on 18/01/2020 09:11:59
                #447438
                Mike Woods 1
                  @mikewoods1
                  There was a discussion of blueing (and blacking) steel in a recent post, which may be useful.
                  https://www.model-engineer.co.uk/forums/postings.asp?th=141342&p=1
                  #447447
                  Steviegtr
                    @steviegtr
                    Thanks all.
