What Did You Do Today (2017)
Home › Forums › The Tea Room › What Did You Do Today (2017)
Viewing 25 posts - 701 through 725 (of 2,518 total)
  • #293808
    Brian H
      @brianh50089
      Is it normal for furnace floors to be made of bronze? I would have thought that some refactory bricks would be used.
      #293810
        Posted by Brian Hutchings on 17/04/2017 20:12:35:
        Only when a crucible of molten bronze runs out of the crack and forms a layer of bronze over the refractory
        #293830
        Raymond Sanderson 2
          @raymondsanderson2
          Thanks Ian & Neil
          Ian no idea although food industry comes to mind for some reason. The gent I got (bought) it off scored a number of them he made himself a Router table from one sold the rest 6 in all if I recall. He had large sheets of the plastic I got his off cut as he only had 4 of those.
          Neil I have been about, but rarely signed in since moving to South East QLD settling in and setting up has taken up a good deal of time. We have been here now about 10 1/2 months. Rather than prattle on the Blog gives an insight https://woolnwood.wordpress.com/blog/
          The other reason is so I get some notifications from this forum again as my subscription is due and I am trying to set up to access my subscriptions off the Tablet we now have. Not impressed with what I went through last night so far grrrrr. Pocket Mags app etc.
          Any how here's some photos of the materials.
          I
          #293847
          Brian H
            @brianh50089
            Quote;" Is it normal for furnace floors to be made of bronze? I would have thought that some refactory bricks would be used.
            Only when a crucible of molten bronze runs out of the crack and forms a layer of bronze over the refractory"
            I really must learn to read things properly before jumping in with both feet!
            #293851
              Nice stock Ray, all you need now is a lump of 1" bronze plate
              #293854
                I fixed my Yashicamat Twin Lens Reflex
                The shutter got 'sticky' several years ago, this seems to be pretty much normal for these cameras when they get to about 50 years old!
                Sadly the leather/vinyl on the front goes hard and has to be removed, but it was four screws to take off the front plate, and five smaller ones to remove the cover, then unscrew the front lens element to expose the shutter.
                The problem is that the grease(only on the shutter button) and oil (on parts of the mechanism) goes thick. I was able to get it going again with carb cleaner, but after it had dried out, sticky again. Flushed it with a more generous dose but by the morning sticky again. Removed an impossibly thin screw to reveal the mechanism by releasing another cover plate and very careful oiling with tiny drops of sewing machine oil and it works again!
                All I have to do now is clean the lenses and replace the front element and outer cover and reattach the mechanism. I may even invest £20 in a roll of Velvia* and processing – I fancy trying some long widefield exposures of the night sky.
                *There's nothing quite as gorgeous as the colour in a medium format Velvia transparency.
                #293891
                  Posted by Neil Wyatt on 18/04/2017 08:55:47:
                  Still far too cloudy here, I'm not even sure there is a night sky any more.
                  And anyway, what's your excuse for playing photography before finishing your Jovilabe?
                  Tut,
                  Dave smiley
                  #293896
                  roy entwistle
                    @royentwistle24699
                    Neil The shutter on my 1961 Rollieflex 3.5E is still as good as new, including the slow speeds. It want's using too but not at £20 a go. Incidentally one of our club members who does weddings tells me that black and white is the current rave.
                    Roy
                    #293901
                    V8Eng
                      @v8eng
                      Using Film cameras, Neil you are very much on trend, as apparently is black and white photography, although personally colour film has always been my favourite.
                      In spite of going mainly digital, I still have a few film cameras that get used sometimes and find you need to keep actuating the shutters and mechanisms fairly regularly to help keep them going.
                      Lenses can also develop (no pun intended) fungus if storage is not correct, bad storage does not do the cameras much good either.
                      Edited for spelling.
                      Edited By V8Eng on 18/04/2017 14:24:10
                      Edited By V8Eng on 18/04/2017 14:30:26
                      #293907
                      Clive Hartland
                        @clivehartland94829
                        Neil, The shutter blades and the diaphragm will get slow and sticky as you say due to oil migration. You have done a first aid and freed the blades but unfortunately there will still be oil in the works. The only real way is a full strip of shutter etc and testing. Oil slows the shutter blades causing speeds to be slow. and oil on the diaphragm will make them hang up and maybe not close correctly. An alternative lub. is Graphite powder which is dry!.
                        #293909
                        Martin Kyte
                          @martinkyte99762
                          Or PTFE dry lube?
                          regards Martin
                          #293917
                          Mike Poole
                            @mikepoole82104
                            Whatever next? people will be buying vinyl records.
                            Edited By Mike Poole on 18/04/2017 15:55:28
                            #293921
                              @mike89748
                              Yes, Mike, I've just unearthed a load of vinyl records, as well as some old 78s which are of historical interest to me. Now I'm looking for something not too expensive to play them on. Any recommendations?
                              Neil: In the same foraging expedition I unearthed some long-expired Fuji 400 asa 35mm transparency cassettes. Admittedly not the best film, but the one preferred a magazine customer I had. I'm tempted to blow the dust off one of the old film Nikons, but I don't know anyone who has an E6 processing line any more. The one I used to use in Aberdeen shut up shot when the press turned digital.
                              #293934
                              Bazyle
                                @bazyle
                                I'll have to ask my work colleagues (all kids under 50) if they have heard of film cameras and vinyl records. Today it transpired none of them had heard of VisiCalc let alone realised that spreadsheets get their name from bits of paper and used said sheets for real work. No I don't feel old.
                                #293935
                                Windy
                                  @windy30762
                                  I'm having a clear out of tools etc. that I have acquired over the years for projects that never got finished or surplus to present day requirements.
                                  This is a checking instrument I bought at Newby Hall Classic Car auto jumble many years ago any ideas what it was used to check.
                                  My thoughts were to use it with modifications to check parts between centres the gauge moves about an inch on its slide.
                                  Checking Instrument?
                                  #293937
                                    Posted by roy entwistle on 18/04/2017 13:45:55:
                                    Roy
                                    Yep, it's not quite he same as digital where we moan at spending £12 on enough storage for thousands of images!
                                      Posted by Clive Hartland on 18/04/2017 14:46:25:
                                      Ah, I could have used graphite powder, I have some.
                                      I don't think the stickiness was the shutter blades, but in the 'clockwork' as both the B and settings of 1/500 to 1/30 worked fine. I did take great care to keep the oil (which is almost like water) well away from the shutter. I think a full strip would not have gone back together…
                                      Colin Osborne
                                        @colinosborne20186
                                        Neil,
                                        I had a Yashica twin lens reflex camera when I was over in Lybia in 1967/8 in the R.A.F. I remember using a pair of binoculars as a 'telephoto lens'. It worked brilliantly!
                                        As for astro-photography, I've not been able to do any for quite a while. Every time things look promising you can bet your house on there being cloud by the time you get set up!!!
                                        Colin.
                                        #293956
                                          Posted by Mike Poole on 18/04/2017 15:54:46:
                                          My daughter does, and not just old ones!
                                            Posted by Mike on 18/04/2017 16:10:48:
                                            I found this the other day:
                                            e6processing.co.uk/product/120-e6-process-scan-and-print/
                                            I used to take mine round to Philip Wright(?) in Coventry (very near where I worked) until I started developing my own. I still have the tanks, last did a few rolls about twenty years ago!
                                            V8Eng
                                              @v8eng
                                              Vinyl appears to be mainstream again with supermarkets featuring displays of (remastered?) vinyl LPs.
                                              I play my own LPs (originals) on a 25 year old Kenwood turntable connected to a newish Denon DAB CD mini unit, sounds really good IMHO.
                                              Most of the good older HiFi stuff I've seen recently seems to be on our local tip!
                                              #293989
                                              Mike Poole
                                                @mikepoole82104
                                                I was in HMV a few days ago and was quite surprised at the quite large display of LPs, had to smile, on the way out I saw a record cleaning kit, did nobody tell the youngsters that although vinyl sounds good it is very high maintenance. I still have some vinyl that I can't replace but I rehomed most of my collection.
                                                #293991
                                                JA
                                                  @ja
                                                  I never chucked out my old vinyl LPs but I now have nothing to play them on. Not all were replaced by CDs and amongst them is some really amazing stuff (or absolute rubbish) from the late 60s and early 70s.
                                                  Obviously I will need a "good" turntable. I understand moving coil pick-ups are hard to come-by and a pre-amp may be required (I have not really looked into this recently). Do I want to, I ask myself?
                                                  JA
                                                  #293999
                                                  Raymond Sanderson 2
                                                    @raymondsanderson2
                                                    I also still have my small collection of Vinyl's mainly The Moody Blues and from there a variety through to classics.
                                                    I say small collection as a mate who is in the music industry (Mastering sound engineer) his Vault as its know houses the equivalent of a double garage.
                                                    I also no longer have something to play them on BUT as the stores here are now again selling turntables **LINK**
                                                    There is nothing like listening to a record in comparison to a CD so many remakes have been doctored an even added to making them very different.
                                                    As for audiophies it was one area I envied to venture into but never did not to say i didn't enjoy doing some repairs on old systems at times.
                                                    Raymond Sanderson 2
                                                      @raymondsanderson2
                                                      Just found this LOL **LINK**
