Unknown Changewheels
Home › Forums › Manual machine tools › Unknown Changewheels
  • #13969
    Martin Cargill
      @martincargill50290
      #484082
      Martin Cargill
        @martincargill50290
        I recently bought a couple of boxes of machine "junk". In amongst all of the bits and pieces appear to be two sets of lathe gear wheels. They are of a strange design and have two pins that provide drive. Anyone have any idea of what machine they might belong to?
        Martin
        #484085
        not done it yet
          @notdoneityet
          DP, axle size, pin size and radius might be good for identification or ‘removal from the equation’.
          #484091
          Pete Rimmer
            @peterimmer30576
            Posted by Martin Cargill on 05/07/2020 14:29:29:
            Martin
            They are quite possibly Drummond gears. Quite popular though I never understood why.
            #484107
            Howard Lewis
              @howardlewis46836
              If you can tell: Bore size, Outside diameter – inches and mm, number of teeth, and thickness, it will help.
              At the moment everyone is wondering how long is your particular piece of string!.
              These details will allow the DP of the gears to be calculated.
              Knowing the DP, the bore and the thickness (Tooth width and centre/hub thickness ), others on here may be able to make a better estimate of what machine the gears may suit.
              #484113
              Martin Cargill
                @martincargill50290
                Just measured one of them, all measurements are imperial
                3.36 diameter
                45 teeth
                0.625 bore
                two pin holes 0.18 and 0.2 diameter
                inside to inside pin holes 0.77
                outside to outside pin holes 1.15
                didn't measure the thickness but I would guess at 0.5
                Martin
                #484122
                David George 1
                  @davidgeorge1
                  I am almost sure that they are Drummond gears. They are probably a missing set or two. Well sort after by people who buy a lathe with non of only some gears.
                  DAVID
                  #484124
                  Pete Rimmer
                    @peterimmer30576
                    Sound like Drummond. I think one hole is straight, the other tapered.
                    Anyway, they should sell well.
                    #484127
                    DC31k
                      @dc31k
                      Posted by Pete Rimmer on 05/07/2020 15:10:10:
                      Because they are 14DP and this size is difficult to find and difficult to find good quality cutters for making them. Used on Chipmaster, early Colchester (maybe Student & Master), Harrison L5 and derivatives (e.g. 140).
                      #484129
                      Howard Lewis
                        @howardlewis46836
                        The DP calculates as 13.98, so 14 DP. So with two driving pins they are certainly not for a Myford.
                        Don't know the Drummond, but sounds a distinct possibility
                        #484141
                        not done it yet
                          @notdoneityet
                          Raglan also used 14DP and 5/8” bore. If original, I would expect them to have part numbers embossed on the casting.
                          #484516
                          Martin Cargill
                            @martincargill50290
                            Thank you for all of your thoughts and information gentlemen.
                            I've been out in the workshop tonight giving the gears a clean up to see what was there. There are four new ( still in bags) 3/4" wide gears that are marked L5 so I assume these are Harrison. There are twelve gears with the double pin holes that I assume are Drummond and two gears without pin holes that I'm guessing are Raglan these are all 1/2" wide. All have the same 14 DP.
                            Martin
                            #484524
                            Nigel Graham 2
                              @nigelgraham2
                              I would concur with that L5 marking probably indicating "Harrison" as I own an L5.
                              There seem still to be a lot of Drummond lathes about, so finding a new home for those wheels should not be too difficult.
                              I'd be interested in the "L5" ones subject to fuller cross-identifying, if they don't suit any of your machines, as the set with my lathe seems incomplete.
